Thread: Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass???
Old 09-12-2018, 10:56 PM   #1
Default Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass???
I just got the 2.0 bec since the old one seemed not quite up to the job on my 4ws bomber. I’m running a 2290 and a 7950, front and rear. I had been using the Holmes double bypass adapter.
The new bec has 2 output wires.
Can I use a splitter / joiner wire to connect the 2 outputs of the BEC together, and just run that to the existing double bypass setup?
Or should I route one to each servo with their own regular bypass?
Some other setup?
Turtlejon is offline   Reply With Quote
Old 09-13-2018, 12:04 AM   #2
Default Re: Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass???
Some other setup?
Not to go off topic but love to see your 4ws in your bomber... did you remove fuel cell??
Sent from my SM-G965U using Tapatalk
"MIS-TAKEN" is offline   Reply With Quote
Old 09-13-2018, 05:57 AM   #3
Some other setup?
Use one power lead from the bec per servo. The new servo has twice the output , but small leads that could not pass enough current.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 09-14-2018, 09:02 PM   #4
Thanks y’all!!
I’ll give it a go!!
I do love the 4ws, it helps in many ways for sure!!
Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass??? - Similar Threads
BEC and 4ws dual servos, intermittent power chalmene Electronics 14 08-28-2016 03:10 PM
Holmes RX Bypass and CC BEC soldering require? Banjoblue Axial Wraith 10 06-19-2015 10:23 AM
Castle BEC, Holmes RX bypass not working MIcrawler Electronics 4 01-07-2015 06:51 PM
how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? ussprinceton2004 Axial Wraith 23 01-29-2012 08:24 PM
