Thread: Led lighting help
Old 01-24-2020, 10:48 PM   #1
Default Led lighting help
I知 going cross eyed searching. I知 building a power wagon body. I got the powershift lights for the power wagon. I would also like to add a light bar. I知 running the mamba x esc and a 3s battery, a Sanws mt4 radio and 4ch rx. The powershift lights say they recommends 12v power. How can I go about wiring this up? Light controller? Anything that would work with this to also control brake lights, reverse lights? Any help would be great.
Lovetoclown is offline   Reply With Quote
Old 01-25-2020, 05:35 AM   #2
Default Re: Led lighting help
I think I can help.
This will let you turn all of your 12 volt lights on and off using a two (or three) position channel:
RC Lighting Control Using External Power
It can take its power from a 3S pack. Ideally, your rig's motor already uses a 3S pack for power and it just gets shared, but if you have to, you can use a dedicated battery instead.
This part will operate brake and reverse lights:
Brake, Reverse and Driving Light controller $30
Let me know if the lights you are going to run are 12 volt and I can make it operate those instead of receiver voltage powered lights instead.
This part does what the two previous parts do, plus a little more:
THE Lighting Controller
Please send me a PM if I can be of further help!
Al
heyok is offline   Reply With Quote
Old 01-25-2020, 10:25 AM   #3
The light product page says the lights Can work on 2s and 3s but better on 3s.
Old 01-25-2020, 02:31 PM   #4
Sounds good. I would just build the external power versions for you.
Old 01-26-2020, 12:07 PM   #5
But it wouldn’t control the brake lights or reverse lights and driving lights correct?
Old 01-26-2020, 12:29 PM   #6
Originally Posted by Lovetoclown View Post
But it wouldn稚 control the brake lights or reverse lights and driving lights correct?
Yes, it does. Just like in the description of the part. It tells about operating all those things, right?
Old 01-27-2020, 07:28 PM   #7
Pm sent.
Old 01-28-2020, 05:35 AM   #8
Pm sent.
Thank you, sir.
I have replied.
Led lighting help - Similar Threads
Led lighting craddock35 Electronics 2 07-13-2013 02:29 PM
LED Lighting Help juswin24 Electronics 7 09-03-2012 07:55 PM
LED Lighting? Drey Electronics 5 01-19-2010 03:17 PM
LED lighting question 86 Iroc Electronics 8 12-20-2009 09:26 AM
