Thread: What are ya'll running for servos?
Old 05-22-2020, 12:58 PM   #1
Default What are ya'll running for servos?
been out of the game for a bit and just completed a scx10iii. I used a HS7950TH that I had laying around and it works great. I'm about to pick up another scx10iii kit and will need a servo. I keep seeing all these different brands of servos that are out now but don't know if they are worth a crap or not. Last time I was involved in the hobby Savox servos were the new thing. So what are all you guys running these days?
josh9mile is offline   Reply With Quote
Old 05-22-2020, 01:10 PM   #2
Default Re: What are ya'll running for servos?
Do you have an approximate budget? If yes, sharing it will help narrow the responses you get.
Personally I use the DS3218MG from Amazon. It's ok. It's cheap. It's stronger that what comes with RTRs, but you can obviously do much better.
rkj__ is offline   Reply With Quote
Old 05-22-2020, 01:16 PM   #3
I would like to keep it around 100ish
Old 05-22-2020, 01:23 PM   #4
Something with at least 400oz/in is preferred
Old 05-22-2020, 02:01 PM   #5
Holmes Hobbies shv500!
Sent from my Pixel 2 XL using Tapatalk
Jboucher is offline   Reply With Quote
Old 05-22-2020, 02:03 PM   #6
Moderator
JatoTheRipper's Avatar
Savox 1230
Savox 2290
Holmes Hobbies SHV500v3
Old 05-22-2020, 02:33 PM   #7
Using a Savox 1210SG myself, never found myself needing more, no issues. Could have longer leads though.
Xx Losungen xX is offline   Reply With Quote
Old 05-22-2020, 04:56 PM   #8
ProModeler 470
Fits your bill , But Jato will whine.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 05-22-2020, 05:15 PM   #9
X2...I have v2
nucklehead is offline   Reply With Quote
Old 05-22-2020, 07:37 PM   #10
Lol jx 75kg servo everyone has alot of bad to say about them but I have 4 and never an issue and ones on a 6th scale custome built 13lb hummer h3 lol
Sent from my SM-G975W using Tapatalk
jokersinsanity is offline   Reply With Quote
Old 05-22-2020, 07:41 PM   #11
Originally Posted by mikemcE View Post
ProModeler 470
Hang up and Drive
I'll bite, I absolutely love the build quality and the fact they're US based but one thing I dont care for is the performance. If only the performance could match its build quality and beefy gears this would be THE servo but I cant recommend it. Everyone's standards are different though so mileage may vary.
For me Savox 2290 or the HH SHV500 V3 but I'm a buy once cry once type.
HumboldtEF is offline   Reply With Quote
Old 06-08-2020, 01:37 AM   #12
Thanks all. I went with the savox 2290. Not sure if I'm totally impressed, or if I'm not feeding it enough voltage. But it seems to stall relatively easily. My HS-7950TH has more power. Kinda upset because I bought 2 of them that my LHS had on special for $119 each.
Old 06-08-2020, 04:37 AM   #13
It wants power...... Hands down a beast at. 8.4v
Hang up and Drive
Old 06-08-2020, 05:45 AM   #14
.. Kinda upset because I bought 2 of them that my LHS had on special for $119 each.
wow...that was a catch
themountain is offline   Reply With Quote
Old 06-08-2020, 12:51 PM   #15
Savox 2290 (hums)
Holmes Hobbies SHV500v2 (silent)
Holmes Hobbies SHV500v3 (hums) I hear if your order from Holmes Hobbies website they can turn it down to reduce the hum on request.
I really like the Holmes v2 servos silent and powerful plus direct to battery connection so no need for a BEC.
Voodoobrew is offline   Reply With Quote
Old 06-08-2020, 01:11 PM   #16
What bec are you using?
Old 06-08-2020, 01:57 PM   #17
No bec. Just 6v from the reciever. I have a CC bec I could use, but my micro servos I have are only 6v friendly.
Old 06-08-2020, 03:06 PM   #18
Get/make a bypass adapter so you can feed just the steering servo 8.4v
https://holmeshobbies.com/holmes-hob...s-adapter.html
Old 06-08-2020, 03:26 PM   #19
What ESC? That thing draws up to 7.5A at 6 volts.
That's probably why you aren't happy with it.
Old 06-08-2020, 03:27 PM   #20
Originally Posted by humboldtef View Post
get/make a bypass adapter so you can feed just the steering servo 8.4v
This ^^^^^ paired with a Castle 10amp BEC set to 8.4v and you're good to go.
Inspector86 is offline   Reply With Quote
What are ya'll running for servos? - Similar Threads
Running Savox Servos Now! alexchen86 Electronics 14 05-07-2013 11:27 AM
Servos, what are you running? throttlejock27 Axial Wraith 77 02-13-2013 03:32 PM
Ya'll running 35T motors, what pinion are you running? concretejungle Axial XR10 9 03-11-2012 08:18 PM
running 1/4 servos yukon635 Electronics 2 05-23-2006 08:25 PM
Running 2 different servos-Help!! Nicklepimp Electronics 6 05-19-2006 07:26 PM
