Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: RcBros Berg Rebuild. Numero Dos!
Old 07-17-2011, 09:47 AM   #301
I haven't checked this build in a while!
rig looks great!!!!
I love the carbon chassis!
every once in a while you will come across a build that has awesome pics of a very clean and sick rig that you can't stop looking at... this is one of those builds!!!!
very nice william!!!!!
Chaotic Crawlers is offline   Reply With Quote
Old 07-17-2011, 12:10 PM   #302
Great pics, Will. Your Berg is one of the cleanest around and my favorite looking rig.
davec is offline   Reply With Quote
Old 07-18-2011, 08:32 AM   #303
Originally Posted by ittybitty View Post
I haven't seen it personally, but I've heard stories of less than desireable consequences of removing the bump on hard landings. These days...landings are becoming more common with all the jumps...drop offs...etc. After dropping the coin for a set of nice gears, spending the time drilling them and the work put into the cases themselves, I'd rather deal with a 2-3mm "bump" than not...
I've blown out 4 3rd gear bearings now and I believe it's because of hard landings and not having the extra screw in the front of the case. Unfortunately, I've lost most of the gears every time.
Originally Posted by RcBro View Post
i don't think I've ever really gotten hung up and said to myself "man if
Only I ground that nub off"
I try my best to drive knowing my tires need to hit first before my axle does.
I got caught up by that bump a few times, to ground it. I'd really like to build some sort of clamp to mount higher up out of the way. Until I find or make such an item, my next set of axles will probably have the bump on them.
EvilTwin v2 is offline   Reply With Quote
Old 07-22-2011, 06:23 AM   #304
Great looking rig Will!!!
Hey, how hard was it to sand down those sidewalls? I've got a set of tires I was thinking about softening up, and you look like you did a fabulous job!
was it a pain in the butt?
WOUrugger51 is offline   Reply With Quote
Old 07-22-2011, 07:34 AM   #305
RcBros Hobbies
RcBro's Avatar
I used a belt sander at work and it was pretty easy and quick.
RcBro is offline   Reply With Quote
Old 07-26-2011, 11:16 PM   #306
Trying to have Fun Again
Red Rockcrawler's Avatar
William how are your cases and tubes coming along?
Red Rockcrawler is offline   Reply With Quote
Old 07-27-2011, 01:31 PM   #307
cars69's Avatar
After a few request and interest from myself as well, I cut our first test knuckles for the enlarged 6x12x4 outer knuckle bearings for the 300 CVD's. These should be available shortly to the public!
But for now here's the sneak peak! Just like our berg knuckles, these are a high steer Zero Ackerman knuckle.
Sweet! I'm glad someone is going to do these.
-Rick
cars69 is offline   Reply With Quote
Old 07-27-2011, 01:38 PM   #308
they've been out for a while. Check out rcbros.com or PM him, Im sure he has some.
TANK is offline   Reply With Quote
Old 07-27-2011, 01:41 PM   #309
RcBros Hobbies
RcBro's Avatar
to slow lol
Old 07-28-2011, 09:07 PM   #310
"HOLLYWOOD"
Mini's Avatar
to slow lol
X2
Mini is offline   Reply With Quote
Old 07-28-2011, 09:50 PM   #311
So how does this compare to the XR10? I'm looking at getting a second crawler and this might be in line!
MitchellY is offline   Reply With Quote
Old 07-28-2011, 10:49 PM   #312
RcBros Hobbies
RcBro's Avatar
I decided to get rid of the XR10 sometime ago. It was not a horrible rig, it just didn't feel as good as my berg. Some believe the XR10 has its advantages, I personally see no advantage.
Old 07-29-2011, 06:14 AM   #313
Originally Posted by Mini View Post
X2
x3
DickyT is offline   Reply With Quote
Old 07-29-2011, 09:12 AM   #314
Hmmm... Berg here I come!
Old 07-30-2011, 10:25 AM   #315
RcBros Hobbies
RcBro's Avatar
Sorry for the delays guys, I had to test some things before I can give the final go ahead on making some sets for my testers. That along with having my machinist being very busy, times have simply not aligned up right. The only thing berg on our axles are the gears, so its been a rather interesting process. As I've said many times, I will not release these, unless I'm confident in them.
Those who have seen what I'm doing with the tubes are insistent these are going to be a big hit, and the best part of all, they will relatively affordable!
Old 07-30-2011, 10:41 AM   #316
Based on the pics of the gear casing that you posted around page 6 of this thread I can't wait to see what the axles and gear cases look like Sounds like it will be worth the wait
vodka child is offline   Reply With Quote
Old 08-30-2011, 06:53 PM   #317
RcBros Hobbies
RcBro's Avatar
Well been awhile since I've updated this thread. Haven't done anything special to the rig since the FXR mod. I've put some time in the rig and haven't had any electrical failures yet. The ESC's do get alittle hot after running for 15 minutes or so but nothing I'm worried about.
I attended the Goldendale Nationals last month and finally walked away with a 3rd place podium finish. It's good to know I can kinda drive now
But the real reason I'm posting is to show you guys some more iphone picture eye candy. We've been working on the cases and tubes some more. A few details I'm still keeping under wraps, but we have updated the case some. We've taken some material out to reduce the width, and rounded the corners for a smoother slide. Its looking pretty snazy!
Direct ETA is still really unknown. There is so much to be done, tested, re-tested and possibly changed.
Old 08-30-2011, 06:55 PM   #318
Very nice! What is the weight savings of these over stock gearcases?
JeremyH is offline   Reply With Quote
Old 08-30-2011, 07:14 PM   #319
RcBros Hobbies
RcBro's Avatar
I cannot recall since my last weigh in, should be over 30 grams or so
Old 08-30-2011, 07:16 PM   #320
Those cases look great (not to mention all the other sweet parts from RcBros). Nice work.
Szczerba is offline   Reply With Quote
