Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: spur gear options
Old 01-15-2012, 12:07 PM   #1
Default spur gear options
i am running an ax10 tranny and was wandering were and what gear "tooth number" to experiment with and where would be a good place to buy from. i get most my stuff from ebay and need to know what to search for. like tooth numbers right now i have a axial with 87t spur, 48 pitch, 23t pinion, 35t integy motor, 3s 90c lipo, sand paws. yeh i know i have a crawler motor in it. but this is just starting this build from a crawler base. i have a 6900kv going in and that should turn it up just a little haha. but what are some spur gears i can play with and where/what to look for.
mudd_slinger is offline   Reply With Quote
Old 01-15-2012, 01:22 PM   #2
Default Re: spur gear options
an associated NTC3 spur will fit part no 2266. its 32p pitch and is tougher than the stock axial spur. you will also need a matching pinion about 14 tooth.
M1tch is offline   Reply With Quote
Old 01-16-2012, 11:57 AM   #3
I'm on 54t Spur / 14t Pinion 32 Pitch...
West Cork Basher is offline   Reply With Quote
spur gear options - Similar Threads
I need help making new spur/pinion gear options. RC youngin Tamiya XC/CC01 5 01-05-2012 02:42 PM
Pinion / spur options for the AX10 trans Mazlem Kyosho Crawlers 3 10-27-2011 08:46 PM
Micro T spur and Micro Crawler spur gear. Same thing? matts175 Losi Micro-Rock Crawler 4 10-15-2011 01:18 AM
Axials Scorpion Pinion and Spur Options BGGruff Axial AX-10 Scorpion 8 11-19-2007 12:35 AM
Wobbling spur gear....Need alum. gear hub! sickfab HPI Wheely King 26 10-01-2007 02:09 AM
