04-07-2008, 03:46 AM | #101 |
Rock Crawler Join Date: Jul 2006 Location: Olympia
So, The axle's, electronic's, DIG, etc. all worked great. On my first run the servo and battery were hitting the Edge because the torsion rod's were so soft. This cause the tierod to bend. I removed the Edge and put a bug body on it for the second course, this really caused issue's. Without the shock's on the rear it exagerated even more how soft the ti rod's were. On my second course I actually went down into a V-crack and when the tires started to climb the rear's came forward and bowed the chassis to literly shorten the wheelbase by a couple inches...lol. Anyway....It was a floppy sloppy mess between the ti torsion rod's and bending tierod that allowed my tires to go in opposite direction's....lol. Here's what I did for TN. I will probably go back to the BTA but not till I can have BigD make me a good tierod. I removed the Titanium torsion rod's and went back to piano wire. I also went to standard steering till after Tn. Here's the new version........for now. I drove it a bit today and wow...what a diffrence..Back to the torsion I know and love, but with more clearance. I really got to play with the Dig a little today. What a great setup...It was quick, solid, and flawless. I can't wait to get the new setup on the rocks............ |
04-07-2008, 09:46 AM | #102 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Glad you had a chance to work out the bugs before a major comp. Please prove to me this set up doesnt work so I dont have to go and spend more money...(I know that wont happen, this is a great set up) Good luck |
04-07-2008, 10:35 AM | #103 |
Nice work Jason, way to evaluate what hurt you at this comp, and remedy it for the next |
04-07-2008, 12:48 PM | #104 |
Thanks Hotwheel's and Tanis........since you guy's were there and actually saw what was going on and what I was doing to "test" I appreciate your comment's!!!! |
04-09-2008, 05:14 PM | #105 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
I musta put too much boy butter on it causing things to loosen up a bit Digged the rig though jason |
04-09-2008, 10:16 PM | #106 |
Rock Crawler Join Date: May 2007 Location: lacey
04-09-2008, 10:35 PM | #107 |
04-18-2008, 02:22 AM | #108 |
05-05-2008, 12:34 AM | #109 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Sucks to hear about all the problems, but good to hear you figured them out and just need to make them better. |
