03-31-2012, 05:25 AM | #21 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!!
Like Manning said. get the compound right first and foremost and you will be golden. If you could produce something with a similar compound to that of the HB red compound with a tread pattern combining HB Khaos and blocks. with a height of 5.7". You will be onto a real winner.
04-02-2012, 06:11 PM | #22 |
RCC Addict Join Date: Oct 2009 Location: Council Bluffs
Honestly i would just prefer a 5.5 tall pin tire with sidelugs, that way people can take them off if they want to, and a compound similar to the hb red dot or the losi red dot. im not a fan of anything taller than 5.5in on a 2.2 because i feel its super difficult to tune foams with em
04-02-2012, 06:28 PM | #23 |
Kratos, no offense, but we already have the tire you describe....the Boss Claw. No reason to put out the same thing again....
04-02-2012, 07:48 PM | #24 | |
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! Quote:
*EDIT* losi site says they are 5.35in tall Last edited by Kratos; 04-02-2012 at 07:58 PM. | |
04-02-2012, 08:13 PM | #25 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Boss claw is 5.0" smaller that the sedonas. Also with small pins I am not a fan of. Larger pins seems to work a little better.
04-02-2012, 08:59 PM | #26 |
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! Depending on wheel and foam, yeah, that's about right. I was just thinking that if a new tire was going to be made, it should be somewhat different than what's already out there....
04-05-2012, 07:58 AM | #27 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
make one like the "khaos" custom tire and you should be good to go. get your tire compound right and a good bead for mounting and you should have a winner! |
04-05-2012, 01:27 PM | #28 |
Rock Stacker Join Date: Feb 2012 Location: Crossville
I'm new to this but does anyone make a larger diameter wheel that would allow you to run a 6" tire with a smaller sidewall? Could be an option.
04-05-2012, 01:38 PM | #29 |
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! |
04-05-2012, 03:29 PM | #30 |
I should have known that, sorry guys.
04-05-2012, 09:27 PM | #31 |
I'm putting the finishing touches on the CAD file right now...I may get it finished up as early as this weekend. It's 5.5 X 2 I'll post a 3D rendering when it's done I'm working with the factory on a custom super soft synthetic rubber compound, things are looking good...very good |
04-07-2012, 07:28 AM | #32 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Why did you go with 5.5"?
04-07-2012, 08:46 AM | #33 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! Exactly. And exactly.
04-09-2012, 10:04 PM | #34 |
^^ What he said
OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! - Similar Threads | ||||
*******ottsix 2.2 schism tire giveaway***************** | crawl-o-matic | General Crawlers | 187 | 03-11-2012 01:32 AM |
Pin Tire with Comp Tire Sidewall - How To Write up | Kraqa | Tires and Wheels | 16 | 08-27-2010 11:55 PM |
input needed | adamargue | General Crawlers | 7 | 06-10-2010 10:25 AM |
Input needed | wrightcs77 | Minnesota | 9 | 04-27-2009 10:46 AM |
your input needed. | Crawler Noob | Chit Chat | 14 | 03-31-2007 11:05 PM |
