05-20-2013, 08:50 AM | #41 |
Pebble Pounder Join Date: Apr 2013 Location: Eastern Georgia, USA
| Re: Motor or Pinion first? Which is better?
My 7.2 battery will last 5 times as long... Both batteries are 2000mAh, so I'd assume they should have similar run times.. I'm not skilled enough at crawling, nor do I have an aggressive enough place to crawl to really use much power, so far. I'd say I do more trail running and goofing around than crawling. The most power-consuming things I do is a somewhat-sandy hill climb that takes wheel speed, and six inch concrete curbs, and zooming around at full throttle and bouncing over things when I get bored. Incidentally, I need shock oil ... soon ... :p DC |
05-21-2013, 05:41 AM | #42 |
Power is what you use to get SPEED. Slow crawling doesn't require much of that, but settles with torque.
Tags |
motor and pinion |
Motor or Pinion first? Which is better? - Similar Threads | ||||
R1 motor pinion | adrians3109 | G-Made Crawlers | 2 | 11-01-2010 08:22 AM |
what motor pinion | damige jnr | Newbie General | 3 | 04-13-2010 01:44 AM |
DNA motor mount. What motor/pinion fits. | sdcrawls | HPI Wheely King | 5 | 04-11-2010 06:23 PM |
Pinion VS Motor | Harvo | Axial AX-10 Scorpion | 4 | 06-26-2008 01:47 PM |
motor and pinion ? | moparman89 | Tamiya Clod Buster | 0 | 02-18-2007 08:11 PM |
