06-02-2013, 07:07 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Tech Thread -- SCX10 shocks
How about we do a tech thread on these shocks. There's bits and pieces of tricks spread all around the forum. Maybe we can gather most of them up here. I saw a for sale ad from Ittybitty for a car and I think he said his scx shocks had: axial rod end balls jeepndoug spring cups for mini-T springs creation fab upper spring retainers bleed holes bladders from 1/16 traxxas Anybody want to add to this list, or provide details, or put up part numbers and sources? Pictures would be nice. Maybe we can get people like Krawlfreak and DelMonte to give up their secrets. I'll start with the part number for the aluminum version. AX30090. They come with phony canister caps, but the plastics bag has regular caps you can put on instead. They come dry. Next... |
06-02-2013, 07:38 PM | #2 |
| Re: Tech Thread -- SCX10 shocks
Traxxas bladders: tra7062 (I believe these have the least rebound but may not seal a second time after a rebuild.) Duratrax bladders: DTXC9182 - what I use. Axial o-rings: axa1179 Associated green slime: 1105 Last edited by Calderwood; 01-18-2014 at 06:22 PM. |
06-03-2013, 08:49 AM | #3 |
Losi mrc silver springs: LOSB1447 Losi mini-t rear springs: LOSB1119 Associated rc18 bladders: 21192 edit: these are really hard and I'm not really liking that they have a slightly smaller od that the duratrax bladders. I could see these getting sucked into the body. Last edited by Calderwood; 08-10-2013 at 11:45 AM. |
06-03-2013, 09:00 AM | #4 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
I have dug around a few times looking for all this info - Thanks! Even links to the threads that are already have tech info would be great.... What is this bleed hole you speak of? |
06-03-2013, 09:11 AM | #5 |
I can't find the thread for Egressor's shock bodies. Are these no more?
06-03-2013, 09:25 AM | #6 |
Mini quake bladders: DTXC9044 (I think these will work since rc18 bladders work and guys use these in rc18 shocks to get less rebound) Axial machined pistons: AX30132 Last edited by Calderwood; 01-18-2014 at 06:25 PM. |
06-05-2013, 05:52 PM | #7 | |
| Re: Tech Thread -- SCX10 shocks Quote:
Find Del Monte's XR10 build thread for photos. | |
06-06-2013, 08:24 AM | #8 |
Rock Crawler Join Date: May 2011 Location: SoCal
Okay, this got me to thinking, and checking back threads. I now kinda believe there is no use for a bleed hole in the side of the cap and here's why. Forget the bladder for now and consider the shock as built -- it's a monotube emulsion shock. Contrary to many local opinions, you HAVE to have air in the shock (all shocks actually). A lot of people go to much effort to get all the air out they can. Which is wrong. When you fill the tube with oil and raise the piston, the shaft moves from outside the body to inside the body. Fluid has to flow out of it's way and needs some place to go. The shock is sealed, so it can't get out. What it does is press on the air bubble at the top and compresses it to a smaller size, allowing everything to fit. If you have too little air, the small bubble has to be squeezed really hard to let the shock compress, so it builds up more pressure which causes rebound. The shock wants to extend itself, separate from the springs. If you have too much air, the piston will poke out the surface and you'll lose damping. So the real issue is to determine how much air is optimum, not how to get rid of it. The amount of air in the cap is too little air for this shock. So there's no need to drill a bleed hole to get rid of some. In fact the trick is to decide how far down the tube the fluid should be before you put the cap on. A bladder changes things some, but this post is long enough already, so later for that. (ps, bladder still doesn't need a side hole. Top hole, yeah) |
06-06-2013, 08:44 AM | #9 | ||
| Re: Tech Thread -- SCX10 shocks In a perfect world, yes.....but these are not. That is obvious by the puddle of oil sitting under them when your truck is on the shelf. Quote:
A bladder can offer some positives, but it is not a magic wand for these shocks. | ||
06-06-2013, 08:46 AM | #10 | |
06-06-2013, 08:53 AM | #11 | |
Regardless, the point is unchanged, that a side-cap hole isn't necessary. Edit: Hmmm....technically not exactly the same. You will have the same amount of fluid and the same amount of air. But the air will be at a slightly different pressure when both are fully extended or compressed which will reduce it's push at full compression, but add a little vacuum at full extension. However, since these devices are scarcely fluid-tight, they're surely not air-tight over a long period and any air pressure difference will probably equalize in short order. Last edited by WAM; 06-06-2013 at 10:46 AM. | |
06-06-2013, 08:58 AM | #12 | |
06-06-2013, 09:48 AM | #13 |
I've found what I like best is to fill the tube about 1/4" from the top (piston extended and bled). I tried Nigel's method, and decided having 1/4" of brass shaft showing on an assembled shock worked out about right. Doing it with 1/2" showing caused my shock to not fully compress. I think either method will work just fine. |
06-06-2013, 10:13 AM | #14 | |
Anyway... On to the Scx shock tech. | |
06-06-2013, 10:45 AM | #15 |
| Re: Tech Thread -- SCX10 shocks |
06-06-2013, 10:56 AM | #16 |
Egressor shock bodies, nuff said...
06-06-2013, 10:59 AM | #17 |
06-06-2013, 11:03 AM | #18 |
06-06-2013, 02:20 PM | #19 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
07-11-2013, 08:02 AM | #20 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
I've read in posts about an "X" ring for the SCX shocks. Anyone have a link? I can't find anything.
Tech Thread -- SCX10 shocks - Similar Threads | ||||
TorqueMaster BR-XL tech thread | JohnRobHolmes | Electronics | 424 | 02-24-2015 12:45 PM |
T Snotz Tech Thread! | Krawler Konceptz | Tires and Wheels | 59 | 02-16-2015 01:23 AM |
Pre-tech thread | War Pig | Scale Nationals | 26 | 09-27-2012 07:37 AM |
