12-09-2018, 11:56 AM | #1 |
Pebble Pounder Join Date: Nov 2018 Location: Wilmington
| Technical performance question.
What is the best way to widen the wheel base/stance just a tad to optimize crawling...with hex nuts, wheel spacers, or deep dish rims? I have a TRX4 Bronco and would like to widen it just a bit, but stay in class 1 rules. Currently the wheels fit about 2/3 of the way under the fender. I'll attach a pic from my phone. |
12-09-2018, 12:20 PM | #2 |
| Re: Technical performance question. Sent from my iPhone using Tapatalk |
12-09-2018, 12:44 PM | #3 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
I just got wider hexes, but idk if im within class rules lol. My body seems a lil more narrow than stock i think Sent from my SM-J327VPP using Tapatalk |
12-09-2018, 04:38 PM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
GPM has some wider wheelhexes for the TRX specific. Or U get the SSD wheelhexes for the TRX and use slw compatible rims. Gesendet von meinem Pixel 2 XL mit Tapatalk |
12-09-2018, 04:45 PM | #5 |
| Technical performance question. |
12-09-2018, 04:59 PM | #6 |
Depends the amount u want to change as wider u go the hex route will give more stress to the axle. But in your case as i see it doesn't matter. Go what give your rig the look you like. The SLW Route ist more flexible cause you can change the hub for your liking. Gesendet von meinem Pixel 2 XL mit Tapatalk |
12-11-2018, 10:25 AM | #7 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
If you're only trying to increase track width a couple mm on each side hexes are fine, but increasing any more than 6mm I would change hubs instead. Sent from my SM-G960W using Tapatalk |
12-11-2018, 10:34 AM | #8 | |
| Re: Technical performance question. Quote:
That’s good to know...I was looking at the Samix 6mm and 8mm hexes. Sent from my iPhone using Tapatalk | |
12-11-2018, 10:38 AM | #9 |
| Re: Technical performance question. |
12-11-2018, 10:43 AM | #10 | |
Is 8mm pushing it? Someone else said that puts a lot more stress on the axles. Not sure why that adds more stress than an offset beadlock set? | |
12-11-2018, 10:59 AM | #11 | |
Sent from my SM-G960W using Tapatalk | |
12-11-2018, 03:09 PM | #12 |
RCC Addict Join Date: Aug 2017 Location: Fredericksburg, VA
Technical performance question. - Similar Threads | ||||
Technical question! | VaOldSchool | Electronics | 10 | 11-28-2018 11:55 AM |
newbie technical question,can someone help? | crawler_fuzz | Axial SCX-10 | 4 | 10-02-2011 09:32 PM |
technical question | camobob | Chit Chat | 6 | 07-01-2011 10:16 AM |
Technical question | Fishmaxx | Electronics | 22 | 05-30-2006 11:19 PM |
