12-20-2019, 05:42 AM | #81 |
Let me 3D Print that... Join Date: Jun 2007 Location: Concord
| Re: New axial.... monster truck?
+ a 12T motor and 60A ESC + lower price of $300
12-20-2019, 06:43 AM | #82 | |
| Re: New axial.... monster truck? Quote:
i wish someone would come out with more upgrade parts for that axle but in the form axial sent them out in they suck and there isent alot of upgrades for them to make them any better i have a few clods and with 35t motors and 12t pinion on 3s it will snap axle shafts on a reguler basis with stock tires or trying to crawl it in the rocks i also break alot of axle tubes and there not vary nice on the gears ether so if the clod is the base line for monstertrucks cause it seems everyonenes comparing the smt10 too it seems to me the smt10 durabulity is right up there on par with the clod only alot more scale not that 8 need or want another monster truck it could be a vary c99l platform to build off of but just like all axial rigs be ready for a $1000 worth of upgrads but atleast they have parts to upgrade with Last edited by ferp420; 12-20-2019 at 06:54 AM. | |
12-20-2019, 09:11 AM | #83 |
Pebble Pounder Join Date: Jun 2006 Location: San Diego, CA
I’ve only had a few issues with the AR60. Mind you my rig is 9lbs with no battery, 3800kv brushless and JConcept GoldYears. I bought some Vanquish v2 axles to lighten up the truck some, the Xtra Speed axles are about twice the weight. I’ve bent two sets of rear axle shafts. All can be attributed to one wheel landings. Both Axial and Vanquish. Trying LockedUp next. The inner bearing on the front knuckle is too small for the weight / load. I kept breaking these until I shimmed the front cvd’s. Front knuckles also come loose pretty often despite using thread locker. This damaged the threads on the Vanquish scale claiming c-hubs ($$). Thankfully fixed with a helicoil kit. Overall they have held up pretty well. After 50+ packs I finally changed the original ring and pinion due to wear.. this is the cheap cast part that came with the RTR. I shimmed everything right out of the box. Front Axial CVD’s, no issues at all. Surprisingly still on the stock plastic diff cup and original gears. I run grease in the front and 100k diff oil in the rear. |
12-20-2019, 11:14 AM | #84 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Are the shocks different? They don't look like the icons to me. I like the idea of the raw kit, just disappointed that they didn't come up with some better axles. I think AR60s look stupid. |
12-20-2019, 11:34 AM | #85 |
| Re: New axial.... monster truck? |
12-20-2019, 08:23 PM | #86 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
what a let down, guess ill just keep building my cheaper mini mt's..
12-21-2019, 07:51 AM | #87 |
12-21-2019, 08:06 AM | #88 | |
the ssd knuckles have bigger bearings to fix that problem and if your running aluminum chubs and some kind of metal axle housings you can locktight the chubs on to the axle shafts and it helps with the sloppy c hubs | |
12-21-2019, 08:27 AM | #89 | |
Axial Racing - SMT10 | |
New axial.... monster truck? - Similar Threads | ||||
Axial bomber monster truck | greazy1984 | Newbie General | 6 | 01-05-2017 06:26 PM |
Axial Monster Truck? | Szczerba | Chit Chat | 25 | 05-30-2016 05:30 PM |
Axial Monster Truck Release? | cmbscx10 | General Crawlers | 10 | 12-22-2015 10:27 PM |
