01-15-2020, 06:50 PM | #61 |
| Re: VS4-10 Ultra
It was brought to my attention that the Ultra is 5mm/.2" wider than the Pro. The width looks close in photos, but is there anyway to bring those tires in more on the Ultra? I'm assuming the wheels are the imitating factor, correct? I'm also contemplating throwing in the 21% OD right away, but I'm torn on that. It seems like the tranny is easy to remove. Thoughts? Which size SLW hubs are used in the video on Harley's channel? Last edited by JatoTheRipper; 01-15-2020 at 07:52 PM. |
01-15-2020, 07:53 PM | #62 | |
| Re: VS4-10 Ultra Quote:
The 21% OD works well with this kit due to slightly less steering angle compared to the PRO. The Portals also have increased castor angle. | |
01-15-2020, 08:20 PM | #63 |
| Re: VS4-10 Ultra |
01-15-2020, 08:24 PM | #64 | |
01-15-2020, 08:31 PM | #65 | |
Eek... decreased steering angle! Why did you give them more caster and sacrifice steering angle? I’m sure there’s reasoning behind it. That makes me feel better not that the increased width bothered me that much anyway. Thanks. Last edited by JatoTheRipper; 01-15-2020 at 08:36 PM. | |
01-15-2020, 09:08 PM | #66 | |
I wanna be Dave Join Date: Sep 2019 Location: US
However, I (and many others) would still prefer the aluminum motor plate, and bearing plates. Quickly getting back to the gears, with the included gears, what is the final OD to the front (compared to the rear)? ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
01-15-2020, 09:34 PM | #67 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: VS4-10 Ultra Good question, I would think it is just because of the use of CVD's as opposed to the Universals. But wonder if there is any involvement "kingpin" alignment or kingpin inclination? I believe the angles are the same so i would lean towards CVD's
01-15-2020, 09:41 PM | #68 |
| Re: VS4-10 Ultra
I was just re-reading the emails I received from Michael Pham (at Vanquish) regarding questions related to using the VFD & VS4-10 chassis on an SCX10.2 based build w/ portal axles. Previously, I had shipped him off giving me "half answers" to questions I had asked. Honestly, I was a bit irritated, and I even vocalized my irritation in a could of threads. However, now, with the release of the 'Ultra', I'm understanding why he answered the way he did. For obvious reasons, he couldn't let-on about the upcoming release, but he also wasn't about to say "it can't be done". Anyway, Micheal, if you're reading, please accept my apologies. And, if you're not reading this, if Brandon it Harley could extend the apology to him, if greatly appreciate it...just tell him, I'm the one who was inquiring about a potential 329mm build. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
01-16-2020, 04:41 AM | #69 | |
Price point was Brandon’s answer. Hang up and Drive | |
01-16-2020, 06:29 AM | #70 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: VS4-10 Ultra |
01-16-2020, 07:28 AM | #71 | |
| Re: VS4-10 Ultra Quote: Oh and guess who pre-ordered a clear Ultra. I so wanted to go with black, but I just can't get over how bad it looks after scratches. If only Vanquish could come up with a proprietary, black aluminum alloy so the black anodize would scratch off to black aluminum underneath. That brings up a question, which aluminum alloy does Vanquish use for parts - 6061 or 7075? I almost went for the Pro, but I chose the Ultra because it is most dissimilar to the Limited. | |
01-16-2020, 08:49 AM | #72 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: VS4-10 Ultra |
01-16-2020, 10:21 AM | #73 | |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
01-16-2020, 10:26 AM | #74 | |
Eh it's not as big of an advantage as people like to claim IMO. The same goes on in the AR world. | |
01-16-2020, 10:42 AM | #75 | |
The plastic motor plate is 6mm thick, made from the best grade nylon we can source. (I dont like sharing exact materials) The VFD transmission is designed to act as a triangulated brace when the skid plate and motor mount tabs are bolted together between the rails. And in turn the rails act as a giant brace for the motor mount/plate. The plastic motor plate will have zero issues, it will not break in its intended application when correctly assembled. The decision to include these components in order to keep the Ultra price point in check were not made overnight. Lots of testing and planning was done even before the VFD transmission was released by itself. | |
01-16-2020, 10:46 AM | #76 | |
01-16-2020, 10:53 AM | #77 | |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
01-16-2020, 11:46 AM | #78 |
| Re: VS4-10 Ultra The CVD's are AR60 size and the same as the original portal design. Which was done to keep the width in check while reducing scrub radius which is typically a huge problem with portal boxes. I also didn't want the chatter of a Universal at max steering being translated through the portal gears.
01-16-2020, 11:50 AM | #79 | |
01-16-2020, 12:00 PM | #80 | |
Quarry Creeper Join Date: Feb 2017 Location: Adirondack Park
VS4-10 Ultra - Similar Threads | ||||
akumu: vs4-10 | v33 | Vanquish Products VS4-10 Origin | 37 | 01-07-2020 08:42 AM |
Mr Hydes >>ULTRA CUSTOM FAB ULTRA 4 BUILD<< | Mr Hyde | 2.2 Scale Rigs | 98 | 06-07-2014 11:58 PM |
