![]() | #41 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| ![]() Stock axial spools and gears suck. I have stripped almost most every gear and rounded out one spool where are axle slides into it.
![]() | #42 |
the problem with those is the screws lossen up then sheer off there were 3 fixes one red locktight on the screws ok for lower power rigs boom racing uses a keyed gear and locker with a vary tight fit making for a bullet proof gear zet or the vanquizh fix that im not completely sold on uses 6 screws also the new axial uses 6 screws on there new lockers and gear sets so i guess its fine ive got a few years on my boom racing gear sets with out any kind of failure i havent even opened the axles since building them if your running high power motors i would go with the keyed boom racing gears way to much beef to sheer but they cost more https://www.ebay.com/itm/Boom-Racing...-127632-2357-0 it seems that extra peed gears also have the key way but there only $1 cheaper https://www.ebay.com/itm/Xtra-Speed-...-127632-2357-0 Last edited by ferp420; 01-08-2022 at 09:45 AM. |
![]() | #43 |
Rock Stacker Join Date: Oct 2021 Location: Mansfield
I already had a VP spool, I hit it with the blue lo tight and put it back together. If it happens again I’ll definitely take your advice with the boom racing gear set Sent from my iPhone using Tapatalk |
![]() | #44 |
Anyone have any suggestions on brass steering knuckles. I looked at beef tubes and ssd but they don’t have the same space for the drag link and the tie rod like the stock VP f9’s do. Sent from my iPhone using Tapatalk |
![]() | #45 |
Rock Crawler ![]() Join Date: Mar 2021 Location: Santa Barbara
| ![]() SSD is the way to go.
![]() | #46 |
![]() | #47 |
![]() | #48 | |
| ![]() Quote:
I have been told stationary mass is better than rotating. I’m really trying hard to get the weight distribution 60/40 or better but there’s a dig on the truck so it’s making it a little more difficult. I was going to try a 3rd member as well but again im having trouble finding one for the SCx.2 style vp f9’s. Sent from my iPhone using Tapatalk | |
![]() | #49 | |
| ![]() Quote:
![]() | #50 | |
| ![]() Quote:
The ssd steering knuckles are on the way. I’m going to leave the brass weights on as well. I’m not doing any bashing with this truck. Strictly a rock crawler. I might try changing out the links in the front from titanium to stainless. That will hopefully get me where I need to be. If I remember correctly the wheels I have only have rings on the inside. I may get them in brass as well if I can find the right ones. Sent from my iPhone using Tapatalk | |
![]() | #51 | |
| ![]() Quote:
![]() | #52 | |
| ![]() Quote:
I have the treal over drive gears in the front diff and the VP under drive in the rear. I havnt done the math but I’m told it brings it to somewhere around 30% overdrive to the front. Sent from my iPhone using Tapatalk | |
![]() | #53 | |
| ![]() Quote:
The rig is sitting at5.7 lbs before the knuckles and links. Sent from my iPhone using Tapatalk | |
![]() | #54 | |
| ![]() Quote:
What about od/ud? I just saw your pic on the previous page. Do you really need that big of a battery? You could probably fit a smaller one up front. If you put your steering servo on your axle you weight is lower. Is that a servo winch in the back, can you move it forward? Last edited by MOguy; 01-11-2022 at 07:59 AM. | |
![]() | #55 | |
| ![]() Quote:
So that 5000 was just there so I could test it. I got the g speed battery tray and mounted it to the frame all the way up front to the right and I’m running tatu 850’s. The steering servo is on the axle. The winch is up front on the left and the servo out back is the dig servo. And I’m running the treal over drive in the front and the VP under drive in the rear. Sent from my iPhone using Tapatalk | |
![]() | #56 | |
| ![]() Quote:
![]() | #57 |
![]() | #58 |
![]() | #59 |
![]() | #60 |
Testing ground | TRIGGER | Redcat Crawlers | 1 | 04-16-2011 06:27 AM |
Ground clearence | carp40 | Axial AX-10 Scorpion | 3 | 06-25-2010 01:13 PM |
ground vs air | bigshafty | Newbie General | 5 | 10-30-2008 12:48 PM |
ground clerence. | Kranberry | General Crawlers | 14 | 05-30-2007 06:31 PM |
From the ground up. | aubie | Tamiya Txt-1 and Juggernaut | 34 | 09-22-2005 08:48 PM |
