03-03-2009, 08:24 AM | #1441 |
Rock Crawler Join Date: Jan 2006 Location: Nebiru, OuterSpace
| shaft question
i just picked up two Crawlmaster Sports -- Planning to use them in a scale 1/6th Rubicon Clod. I'm curious John if you've ever had anyone complain or discuss bent shafts when the motors are used in this fashion. I know your site indicated they could be used in a clod. My concerns are this: I bought two used Hyperion 3013-14 outrunners intially(very similar to the crawlmaster sport), used from a member on the forum. He got them used from another and didn't know much about them and therefore the asking price was CHEAP (these are normally a bit more expensive than a crawlmaster). He agreed if there was anything wrong with them to refund. I got them and installed - turns out both had bent shafts. I returned for refund. They were initially 5mm shafts, but had been turned down by someone along the way to 3.17mm. I don't know but I assumed the shafts got bent in a Clod because the cans were scraped up (from dragging across rocks possibly?). Figure that same scraping also places pressure on the can and that could bend a 3.17mm shaft i assumed, espeically that the shaft has some material removed to flatten for set-screw, making it all the thinner/weaker. So i bought the crawlmasters but now i'm worried i'll trash them on the rocks by bending the shaft in the same manner that the Hyperions were bent. Looking at your crawlmasters, looks like they originate with a 5mm shaft and you must have them turned down to 3.17mm and flat side added for set-screw as well. 1. Do you know of anyone who has brought to your attention bending of shaft when used in a clod? Or do you feel the potential for bent shafts is significant used in a heavy clod crawler. 2. If I returned these crawlmasters to you, would you be able to exchange them for crawlmaster motors that haven't been turned down, and still have 5mm shafts? Thanks John, I'm just guessing with a full 5mm shaft there is little chance of bending the shaft --- and i have the 5mm bore 12tooth pinions that would work well for my rig (on 4s lipos). My clod weighs 15.5lbs so i'm thinking so much weight will easily bend the smaller 3.17mm shafts if there's alot of rock-rub going on --- was thinking of trying to add a skid plate below the motors, but it may just be easier to get ahold of outrunners with 5mm shafts Thanks either way, Ron Last edited by WRXronald; 03-03-2009 at 08:27 AM. |
03-03-2009, 09:34 AM | #1442 | ||||
The worst issue from beating the motors on the rocks is that you can knock magnets loose or weaken them. | ||||
03-03-2009, 01:40 PM | #1443 | |
I'll hold from now on the 5mm shafts and see how the 3.17mm's work out (this way i can really gear down to the 9tooth pinions). That was another thing i noticed, it almost looks like the shaft could be swapped on these Crawlmasters (secured by set-screw and e-type clip), would that be accurate? If so I have to say that is brilliant --- any damage to shaft and you don't have an all out loss on the motor, just rebuild motor with new shaft. That is why the hyperions got send back -- i couldn't see how i was gonna rebuild or source new shafts for them. Thanks for the info --- very helpful !!! | |
03-03-2009, 01:53 PM | #1444 |
Yep, the shaft is replaceable. Take off the eclips and the motor comes apart. Loosen up the screws and then you can use a 4.7mm punch to push out the old shaft with a drill press or rubber mallet.
03-04-2009, 08:32 PM | #1445 |
Quarry Creeper Join Date: Jun 2008 Location: Mesa
John, You told me to email you regarding a refund on some berg pinions, but i have heard no response when i sent my request through your website, please let me know what email address is best to contact you through Thanks Kolby |
03-04-2009, 10:58 PM | #1446 |
Rock Crawler Join Date: Nov 2008 Location: SoCal
Do you know when these will be back instock? Holmes Hobbies 25C 1300mah lipo 3S Packs |
03-05-2009, 06:49 AM | #1447 | |
I am waiting on the factory, it may be a few weeks out still. | |
03-05-2009, 11:56 AM | #1448 |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
| How big of servos is big enough
I'M BUILDING MY FIRST CRAWLER IT IS A SUPER I WOULD LIKE TO KNOW WHAT SERVOS WOULD BE BEST FOR MY RIG...HERE IS A PIX OF IT PLEASE LET ME KNOW... YOU CAN EMAIL ME THE ANSWER OR I WILL LOOK AGAIN AFTER WORK... THANKS JEFF.. |
03-05-2009, 02:46 PM | #1449 |
Quarry Creeper Join Date: Jan 2008 Location: Dahlonega
| Got a question
I am having a problem with my rig shutting down now since installed my HH7t, what could be causing this? Here is what i got as far as electronics. ESC: Fxr SERVO: Hitec645mg BEC: CC BEC BATT: Elite 1500 2/3A 7 cell AUX port: Light kit (got 4 white lights, 2 red lights, 2 blue lights. |
03-05-2009, 02:52 PM | #1450 |
Quarry Creeper Join Date: Oct 2008 Location: Spanaway, Wa
03-05-2009, 04:09 PM | #1451 | |||
03-05-2009, 05:06 PM | #1452 | |
03-05-2009, 05:08 PM | #1453 |
Thats kinda crazy! What kind of radio?
03-05-2009, 05:09 PM | #1454 |
Dx 3.0
03-05-2009, 07:15 PM | #1455 |
JRH... Does your site tell when you are out of something? I need a Tekin FXR, a CC BEC, and some of your silicone wire. Do you have all that in stock? And... what gauge wire do you suggest for wiring a berg ? Thanks |
03-06-2009, 05:12 PM | #1456 |
John, I finally got my eletrical issues worked out (the servo was not grounded to the Rx). Now I just want to know is this normal or do i have something set wrong on my Dx 3.0. It seems to me that my cobalt 7t runs faster in reverse than it does in forward. And also it sounds like the motor is turning alot more rpms in reverse to.
03-07-2009, 01:00 AM | #1457 |
RCC Addict Join Date: May 2008 Location: On the rocks
You wouldn't happen to have a ETA on your new batch of ProWound 540's would you? Thanks for you time.
03-07-2009, 02:00 PM | #1458 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
I just placed an order for 2 55's but if your going to get some 45's in,I can wait.I added a note to my order #3175.Thank You CD |
03-07-2009, 08:34 PM | #1459 |
Quarry Creeper Join Date: Aug 2008 Location: back where I belong
So JeremyH got a 7t puller and now I want one. I'm plannign on getting either a mamba max or fxr. I stil dont know which one. but I know the 7t puller will work with the mamba max, would it also work with my rooster crawler edition? |
03-07-2009, 11:20 PM | #1460 |
Pebble Pounder Join Date: Feb 2009 Location: Cda, Idaho
Mr Holmes, thanks for getting my new p-94 and sidewinder to me, it was like freakin Christmas when they got here. Just wondering if I can order extra brushes and springs yet. I know you said the p-94 was discontinued so I would like a extra set of brushes, and maybe a couple of batteries a new charger a bec etc etc etc.... Thanks
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
