02-25-2008, 02:35 PM | #441 |
Rock Stacker Join Date: Nov 2007 Location: Tenino
Hi John, I have tried emailing through your site a number of times over the last week or so and have not heard back. I am wanting to order the Mamba Max/CC BEC/7t Puller Combo, it looks like there were still 7t Pullers available for preorder, is there anyway I can preorder the combo? |
02-25-2008, 07:42 PM | #442 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
JRH, I was wondering if the elite 1500 2/3 cells have enough capacity/amp draw for the puller motors or simular. It seems to me they may not and want to use one of my 8 cells in a 5 turn drag motor for the scale comp. Am I correct or do I need to adjust the gearing to match the ability of the battery ? I want mega wheel speed and still retain my torque. I can always go lipo in this rig but really dont want to hassle with waterproofing that also, and the sharing batteries thing......... |
02-25-2008, 09:54 PM | #443 |
For crawling the 1500 cells are fine. For pulling I would use two packs in parallel. Amp draws on the 5t will probably want to get past 60 or more in a hard pull (if you have that much load). But, for normal scale use it is plenty of power. Without a data logger it is hard to say where the gearing will want to sit, but gearing down is never a bad idea. |
02-25-2008, 10:00 PM | #444 | ||||||
Cool, I will check it out in the morning and respond with the rest of the emails that I am two days behind on Quote:
02-25-2008, 10:30 PM | #445 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
hey jrh, i need a new esc, or esc motor combo....... i have a brand new integy v10 55t, r2 tranny, wk axles/locked w/cvd's, 2-jrz9000t servos for 4 wheel steer, dx3 radio, and running maxx sized tires. the truck has decent speed and torque, but bogs down runnin both the servos, and motor. I am assuming i will need a cc bec, and a new esc at least. i was lookin at your brushless systems but i dont want too much power to start breakin stuff.... what would you reccomend as far as just an esc, and also a motor/esc combo? thanks for the help..... |
02-25-2008, 10:41 PM | #446 |
I would say a CC BEC will fix most of your woes. For an ESC the Sidewinder is fantastic for both brushed and brushless. For a motor, the Revolver Black is a nice decent sized outrunner. I should have them in about 4 weeks, and in the mean time you can run the v10 and have fun with drag brake.
02-26-2008, 08:42 AM | #447 | |
thanks jrh i will be ordering a sidewinder and cc bec from ya within a couple days..... thanks again Quote:
02-26-2008, 09:47 AM | #448 | |
Can you tell me the amp draw capacity on the 1500 elite's. | |
02-26-2008, 01:34 PM | #449 |
1500's will burst and recover from 35 amps pretty easy. Anything much over 25 to 30 amps for more than 5 seconds starts to fade them down. With battery bars I bet you could get some 40 or 50 amp bursts off the cells pretty easily. The hotter the cells, the better.
02-26-2008, 04:41 PM | #450 |
Rock Stacker Join Date: Feb 2007 Location: Aussie Crawlin Sin City
Hi john I have a question for you on the quark procar 33 and I believe your second generation revolver b/l motor it has a white label with your logo and a blue can anyway when i turn it on it doesn't give the last set of beeps until i move the spur and hold the throttle is this a motor or speedie problem ?
02-26-2008, 04:44 PM | #451 |
The Quark needs a throttle blip to arm (or your throttle trim isn't centered to the ESC). Until you bump the throttle it wont give the last set of beeps.
02-26-2008, 05:39 PM | #452 |
WOW thanks for the fast response you da man
02-26-2008, 06:17 PM | #453 |
Quarry Creeper Join Date: Sep 2005 Location: VARCOR
John is one better then the other... the mamba 25 or sidewinder. I will be using a 45t brushed motor for now but will upgrade to brushless later. I plan to run around 9 cells. Thanks
02-26-2008, 06:41 PM | #454 |
Sidewinder is for you. The M25 wont take the 45t 540 motors.
02-26-2008, 06:46 PM | #455 |
Thanks, is the castle link on your web site for the sidewinder? If I was replacing the 45t would you recommend the crawlmaster 1000. I still want wheel speed and torque. thanks
02-26-2008, 06:50 PM | #456 |
Yes, the Catle link on my site is for computer programming the Sidewinder. The Crawlmaster 1000 is a good crawling motor all around. You might have a reduction in wheelspeed from the 45t.
02-26-2008, 07:31 PM | #457 |
Pebble Pounder Join Date: Oct 2007 Location: Allentown
Hey John, not to be a pain but i had sent a question through your website a day or two ago and have not received any feedback yet. Did it even go through or are you guys just backed up?
02-26-2008, 07:35 PM | #458 |
Just a bit backed up on emails, I haven't tended them today yet. I have been flying by the skin of my teeth the past week or so with school hitting hard at the same time as shipping out the 10t pullers.
02-26-2008, 10:04 PM | #459 |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
Quick question I have 2 rigs. Both Axial, both stock trans, axles blah blah blah. Rig #1 is running a mamba max, with a crawlmaster 850. Great low speed crawling, awesome torque. Rig #2 is running a mamba 25 and an OG revolver. Great low speed crawling, awesome torque, UNFREAKING BELIEVABLE top end. Both rigs are running stock spur gears, 15 tooth pinions, and indentical settings/throttle curves. But holy crap does rig 2 (my sons) out run my rig like mad. Top end wheel speed is insane. When you need to BUMP and throttle out, his rig gets it. My rig will spin em, but nothing like I would expect. Should I be setting up my mamba max differently than a mamba 25 to get more top end out of it? |
02-26-2008, 10:55 PM | #460 |
The crawlmaster 850 is just a slower motor. You could use more voltage to get more speed out of it.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
