Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: My comp purpose Venture
Old 08-24-2018, 10:50 AM   #41
Default Re: My comp purpose Venture
As we are getting closer to take part to G6 Revon in Italy, last minute touches are being made.Front aluminum bumper holder and a hook to have something to be grabbed from.And not to forget, general switch wich cuts off power even with the battery pluged in.Stay tuned, more to come
Sent from my SM-G955F using Tapatalk
Traulus is offline   Reply With Quote
Old 08-30-2018, 11:01 AM   #42
So as G6 Recon in Europe is getting closer, I am almost done with my rig.Added a full interior and 2 warrior driver and co-driver
Old 09-14-2018, 11:22 AM   #43
Back from G6 Recon in Italy, the truck performed outstanding, did the 12 hours gix endure with no breakage,the car went smooth, also passed with success the next day TTC Challenge.After this event, the HPI Venture is now G6 Recon Certified
Old 09-16-2018, 03:52 AM   #44
This is how the car looks after G6.I had couple of screws loose and 2 missing
Old 09-16-2018, 01:34 PM   #45
Homemade wheel wells?
Sent from my SM-G965W using Tapatalk
J.hyland is offline   Reply With Quote
Old 09-17-2018, 12:54 PM   #46
Yes, 3d printed
Old 09-17-2018, 12:55 PM   #47
What a shame haha. Been waiting for someone to release some
Old 09-20-2018, 01:45 PM   #48
Well I can print you some if you want.I haven't see any on the market yet
Old 09-20-2018, 01:54 PM   #49
That would be nice! How much? Also I live in BC Canada so shipping may be a bit too much for me
Old 09-23-2018, 01:51 PM   #50
I will be checking the postage for you and see whats the shipping cost
Old 10-08-2018, 02:30 PM   #51
After running the G6 in Italy, my front aluminum bumper holder, started to get used and the holes where bigger because of the abuse that the front stinger fot, so I decided to replace it with solid metal
Old 10-14-2018, 01:54 PM   #52
This weekend I attended a local comp, 2nd place in Hill Climbing and 2nd place on Team Trial.Cvd's is all she needs!!!!
Old 11-09-2018, 11:42 AM   #53
Power up, Tekin 3100kv ROC412HD
Old 11-09-2018, 02:55 PM   #54
I am in touch with Frank from HPI and he said that Christmas Sale would be the release date for them.Hope that's true
Old 11-10-2018, 10:30 AM   #55
I think I had 5 minutes of runtime with the new motor.Conclusion?Could be to much to handle?Or it was just time to give up after 1 year of hard trailing
Old 11-16-2018, 01:58 PM   #56
We made it on the official HPI webpage, it feels awesome!!!!!
https://www.hpiracing.com/en/article/view/2018091202
Old 11-22-2018, 12:29 PM   #57
After breaking the rear diff I decided to shim the atack pinion so I added teo shims on each axle on the outside, just before adding the driveshaft
The motor is a real beast, so I had to gear it down, using a 17t pinion, this is the smalest I could get on the 5mm bore and swapped with the optional spur 60t
Also, after running the G6 in Italy and the 12 hour fix enduro, I haven't open the trandmision, so I had to do it. What I found inside, was a mess, but evrything was working, so cleaned the old grease and replaced it with a new one. Everything is perfect now. Waiting to see how it handles on the rocks
Old 11-25-2018, 10:01 PM   #58
On the idler gear, I replaced the stock one( 60t I believe) with the hot racing 58t gear. The stock bearings don’t fit my 58t gear Did you run into that problem?
hoghead5150 is offline   Reply With Quote
Old 02-21-2019, 09:14 PM   #59
I was told by another member to reach out to you about your inner fenders. I’m curious how much you would charge to print me some. PM me so we can talk about it. Thanks!
jason02ws6 is offline   Reply With Quote
Old 02-23-2019, 06:25 AM   #60
CVD's are on, hoping for improved steering angle
My comp purpose Venture - Similar Threads
MT Venture TAT76 HPI Venture 51 01-29-2020 12:32 AM
The venture is here! Jfrisch01 HPI Venture 127 03-06-2018 07:34 PM
RC Screws for Venture dwblue00 HPI Venture 0 12-28-2017 08:54 PM
TURBO'S first 1.9 comp venture... TURBOFEST Losi Mini-Rock Crawler 38 03-04-2010 02:06 PM
Another venture. aubie Chit Chat 6 12-25-2005 05:35 AM
