08-27-2009, 01:13 PM | #21 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
08-27-2009, 02:20 PM | #22 |
Shock are rebuilt and mounted up! 40 WT and 1.8 rate springs rear. 35wt and 1.4 rate springs front. ( Changed after i took the pic!) Going to try the links and shocks setup like this first. Sits a hair over 3 inches of clearance like this. Mocked up with some assassins. |
08-27-2009, 02:28 PM | #23 |
Pebble Pounder Join Date: Jun 2009 Location: Canada
This is a cool build thread! The rig looks great. |
08-27-2009, 02:34 PM | #24 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
I love live builds, and this chassis is interesting, almost makes me wish that I didn't get rid of the WK tranny! Glued to the screen... |
08-27-2009, 02:51 PM | #25 |
Pebble Pounder Join Date: May 2009 Location: Capitan N.M.
I run only WK crawlers. so this will be watched allthe way. was wondering what kind of dig unit you where working on converting. personaly i used a ckrc axial dig unit with a custom made back plate and never had a problem with it. also have one set up on my torsien chassis, on a stelth tranny. great work sofar and cant wait tosee the rest.
08-27-2009, 02:54 PM | #26 | |
I will probably have to do a driveshaft dig setup. Going to go work on driveshafts and electronics next!! | |
08-27-2009, 04:34 PM | #27 |
RCC Addict Join Date: Feb 2007 Location: MS Coast
Lookin good so far. I cant wait to see how it performs. I just pickup up a Bully to try out. I still aint sold on the whole MOA stuff.
08-27-2009, 04:40 PM | #28 | |
Well got it to a roller. Just have to install electronics and put the tires on the stalkers. Having a fit with this castle software. Cant get it to recognize the bec on vista or XP!! Fixing to take the wife to dinner then i am gonna fire up the hakko when i get back. Driveshafts are on. | |
08-27-2009, 06:44 PM | #29 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
need more shots of different angles good buddy Get with me if you have any questions...it is a climber tho! |
08-27-2009, 07:28 PM | #30 | |
Will get some outside tomorrow. Getting the electronics soldiered up now. This cc bec took up lots of time trying to up the voltage on it. ( Never got it to work). Going to go get some Jato rod ends and something to make a electronics tray tomorrow. Got this much done today. | |
08-27-2009, 07:57 PM | #31 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Does the chassis flex much at the shock mounts?
08-27-2009, 08:11 PM | #32 |
| It is very stout! It does a very little but not much. I plan on making a electronics tray above the motor tomorrow. You could put a brace between the sideplates if flex was a concern also. Got the tranny today cali, Thanks |
08-27-2009, 08:57 PM | #33 |
No problem man. I was worried cuz the tracking number wasn't recognized.
08-27-2009, 09:42 PM | #34 |
What is your center clearance at?
08-27-2009, 10:13 PM | #35 |
08-28-2009, 04:45 AM | #36 |
| With the links and shock setup like it is now it is 3.1/8th inches. The pumkin clearance is 1.5 inches. These link/ shock mounts really tuck up close to the axle for better clearance. I was close to getting all the electronics ready to install last night and did this. ( male to male plugs on motor leads!!) Planning on making some electronics trays today after a trip to lowes and local hobby shop again. Last edited by rottenbelly; 08-28-2009 at 04:48 AM. |
08-28-2009, 08:07 AM | #37 |
I was thinking of something like this for a electronics tray/spot. With only a tekin fxr and a spektrum rec i dont think it will affect my cog to bad. What do you guys think? This will be temporary till i get some delrin. I think i could also do some kind of L-bracket to drop it down a little closer to the top of the motor. Also notice in the pic below i switched out knuckles and c's. Put on some RCP crawlers clockable c's and knuckles. I was having clearance issues with the srtc ones. Last edited by rottenbelly; 08-28-2009 at 08:11 AM. |
08-28-2009, 09:12 AM | #38 |
I like the electronics plate. But if you can lower it do it. I don't think of will matter much with that tiny esc and receivers weigh next to nothing. If anything lower it so the body won't have a change to rub.
08-28-2009, 09:14 AM | #39 |
Looks sick tho, can't wait to see it crawl.
08-28-2009, 01:38 PM | #40 |
Been working on getting the steering and battery plate dialed in. Got this from a fella on here and decided to use it. had to make a few modifications to it. Wanted to make sure i had this servo bolted down good. Putting electronics in next!! |
