Like Tree1Likes
Thread: Free WK servo mount templates
Old 03-25-2007, 09:49 AM   #41
JIA's Dad's Avatar
Harley, I don't understand why the steering was moved behind the axle. Unless some one thought it would give more clearance than in the front. In a frontal view of the axle the flat portion of the pumpkin is on the left side. The drive shaft is on the back side of the axle.
JIA's Dad is offline   Reply With Quote
Old 03-25-2007, 10:05 AM   #42
Hottest Axial rigs, EVER.
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Yes, it was moved behing the axle for more approach clearance and less hang up opportunities. I am obviously going to keep both versions, standard and behind the axle.
The BTA setup takes more work but it could be a substantial improvement.
I mostly did it though just for fun
Josh Thiede
Harley is offline   Reply With Quote
Old 03-25-2007, 10:09 AM   #43
JIA's Dad's Avatar
Thanks clears it up for me. Has it been tried, the clearance between links and steering looks to conflict.
Old 03-25-2007, 10:39 AM   #44
Harley's Avatar
yep heres a pic.
I just used a k2-3l Chassis because it is my prefered chassis. I am sure it would work with alot of different chassis'. I cycled the suspension and there were no conflicts.
Old 03-25-2007, 12:31 PM   #45
JIA's Dad's Avatar
Yes, I see that could work fine. You are very good with that program. Thanks for what you are doing and have done in giving options on setup to all. The only possible problem I see with this setup is, that spacer on the steering connection acting as a lever putting extra torque on the steering arm (twist/slack). Unless the C/steering arm is made of aluminum like on other (already sold parts like on TLT/Clods) add on parts.
I think there are enough ideas posted for the average person (he/she) to have options on how they would do their setups. Thanks again for all you have done.
Old 03-25-2007, 01:03 PM   #46
Harley's Avatar
I agree 100% about the torque on the knuckle. Seems like aluminim knuckles are one of the first aftermarket parts to come out for new vehicles though.
Anybody know of a better site to upload the templates on that doesn't have a limit to the number of downloads per day. Or since I bought my star can I upload them on here?
Josh Thiede
Old 03-25-2007, 02:13 PM   #47
ΜΟΛΩΝ ΛΑΒΕ
dezfan's Avatar
May have to limit the size if you load them directly to RCC.
Are you using Photobucket?
I haven't noticed a limit there.
dezfan is online now   Reply With Quote
Old 03-25-2007, 02:42 PM   #48
Harley's Avatar
I still load my pictures to photobucket, but I want to upload the PDF files. I could probably convert them to a JPEG but I wouldn't want the scale to get messed up. Maybe someone that has a website on here would host them for us.
Old 03-28-2007, 09:20 PM   #49
Harley's Avatar
Looks like it worked!!!!
Here is Gula's...................HIS IS TITANIUM!!!
My K2-3L Rubi With WK axles "In progress"
Old 03-29-2007, 01:28 PM   #50
Saweeet!
NickRummy is offline   Reply With Quote
Old 04-04-2007, 11:25 PM   #51
If some one can make this or will make it. i would buy a version for the front and the rear. I don't have the tools or the room to make these.
Originally Posted by Harley0706 View Post
yep heres a pic.
Project Dad is offline   Reply With Quote
Old 04-05-2007, 12:09 AM   #52
I second that
neverupright is offline   Reply With Quote
Old 04-05-2007, 06:57 AM   #53
Harley's Avatar
I am up for having a vendor make and sell them, I would not be holding them back. I am willing to give them my template to make it easier.
Bug your vendors guys.
Josh
Old 04-05-2007, 03:06 PM   #54
Harley's Avatar
Today when I was cuting out the template for the new clocked motor plate I noticed that it printed smaller then 1:1. I checked the paper template against the design and concluded that Adobe PDF Maker actually shinks the print by almost 5%. So I corrected the output size and everything should be good now. This is the reason why the servo mounts were not lining up 100% correctly (more like 96% correctly). With things this small it can really cause a problem. If I would have had an axle here to check it against I could have caught this alot sooner. Anyways, a new template is available for anyone who wants it.
Old 04-06-2007, 12:05 AM   #55
JIA's Dad's Avatar
Josh
(This is not to be used for anyone to profit from!!!! Think of it as shareware not freeware (I think that is the right analogy).)QUOTE
Josh Thiede
That's really smooth Josh pick our brains to get all the info for the designs, which originally were not to be used by vendors. And now you say Your not going to hold them back, they can sell us a product that we helped design. Do we get to share in the profits?
Old 04-06-2007, 06:38 AM   #56
Harley's Avatar
....I am willing to give them my template to make it easier.
I don't want to sell it. I am never going to make this thing. I just wish I had time for my own stuff.
I will always give this template to people, I just think it would be nice for people to be able to buy it. My template will always be shareware though.
Josh
Old 04-11-2007, 12:35 PM   #57
Finished the Servo Mount today, no linkage yet hopefully i can do that tonight.
Mriccucci is offline   Reply With Quote
Old 04-11-2007, 09:48 PM   #58
Harley's Avatar
Looks good!
Can you get a shot from directly behind the axle if you get a chance?
Josh
Old 04-11-2007, 10:07 PM   #59
I have a question(probably a simple answer for it, I feel dumb asking)...why is the servo off to the side on all the mounts I've ever seen? Does it have to do with the clearances on the pumpkin?
BTW, nice idea, I'm sure my WK will get this eventually, I was wondering something else also...wouldn't it be beneficial to have the BTA setup? I look at the front setup and it just looks like it's begging to be smashed in a front end collision. I know crawlers aren't that fast but what happens if you land on the front of the truck coming off a rock face or something? Just trying to think ahead..
joemomma95 is offline   Reply With Quote
Old 04-11-2007, 10:24 PM   #60
Harley's Avatar
The servo is off to the side for two reasons:
1: To keep the height down. With how low we like to run our rigs it is nice to not have an axle setup that isn't 4 inchs tall.
2: Keep the Center or Gravity as low as possible.
and on the TBA setup:
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
