06-04-2007, 05:47 PM | #41 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
STUPID question here!! About your rock rings. Will the tires mount without glue. Have not seen beadlocks yet in person do not know exactly how they work??? |
06-04-2007, 06:00 PM | #42 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
06-04-2007, 07:07 PM | #43 | |
Rock Crawler Join Date: Dec 2005 Location: houston
How-To: Functional 2.2 Beadlocks for under $30 | |
06-04-2007, 07:45 PM | #44 |
| Getting Close!!
Got some more work done. The chassis is painted with three coats of metallic silver and two coats of clear. The body panels are lexan with carbon fiber stickers on the inside of the lexan, and trimmed Wheely King stickers. Also made some limiting straps out of shoe laces that limit the droop and flex. The shocks have 1,000 weight oil in them and no springs. Got the rock rings painted and mounted and the foams trimmed. There is 3oz of stick on weight in the front tires and 2oz in the rear. Gears are 96T spur and 15T pinion with a 65T lathe motor. Still need to build a battery mount and mount the rest of the electronics. Here are some poser pics... And full flex... soooo.... watcha think?? |
06-04-2007, 08:32 PM | #45 |
The thing sucks ! I will pm ya my addy so you can send to me I will dispose of it for ya.. this thing is very pimp !!!! check out my sig, if you want to go to comps and don't mind driving.
06-04-2007, 08:57 PM | #46 |
Pebble Pounder Join Date: Mar 2006 Location: Asheville,NC
Looks great! That's some nice work.
06-04-2007, 09:41 PM | #47 |
Rock Crawler Join Date: Nov 2005 Location: dallas
Nice lookin tuber |
06-04-2007, 09:47 PM | #48 |
Thanks guys, wasn't sure about the carbon fiber look, but I think it turned out alright.
06-04-2007, 09:49 PM | #49 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
06-04-2007, 09:52 PM | #50 |
06-07-2007, 04:53 PM | #51 |
get it done and let us know how it crawls and how that droop setup works out
06-07-2007, 05:35 PM | #52 |
^^^ I'm working on my battery mount, then it should be ready to wheel. Also, still can't decide between the rear steer or front dig. Any ideas?
06-07-2007, 07:42 PM | #53 |
Well, I have done them both on my crawler. I think non crawler people think the dig has more of a cool factor. Plus it is legal if we happen to end up in a comp somewhere. I did my dig with max shafts and just dremeled the small channel on the male end to be the same size as the large channel. I can shift on the fly and it hasnt missed an engagement yet. I didnt give the 4ws enough of a servo and it kept having servo holding problems. It would turn around in a 3ft circle though! It prolly helped more than the dig, but like I said the stock WK servo didnt have enough guts. |
06-07-2007, 09:00 PM | #54 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
Looks great...I am running CF on my hustler as well....looks killer!!
06-10-2007, 07:42 PM | #55 |
Pebble Pounder Join Date: Mar 2007 Location: reno
what do you use for your links
06-11-2007, 08:11 PM | #56 | |
I used carbon fiber arrow tube and inserts from the local archery shop. Just cut the carbon shafts to length, then glue the inserts into each end, and thread the ball ends in. | |
06-11-2007, 08:20 PM | #57 |
Finally got her running. I still need to put on the rear steer and zip tie my wires up out of the way. The droop set up with 1,000 weight diff lube in the stock WK shocks is working great. It also works much better with limiting straps that limit the amount of center droop. This keeps the axle from walking under the buggy when trying to climb a ledge, and also limits the articulation some too. With the slower movement of the shocks from the 1,000w oil I can float a tire across a hole with a little throttle before the suspension allows the tire to fall into it. So far I'm loving the set up. I also re-geared to a 96/13 and its just right for the kind of wheeling I do. Nice slow crawling, but still has enough wheel speed when I need it. The Mashers are working pretty well, I star cut the foams and grooved the center of the foam too. Gives just the right amount of tire flex IMO. I also put 3oz of weight in the front tire and 2oz in the rear. Sorry for the long post, just thought I'd share what's working for me.
06-11-2007, 08:26 PM | #58 |
Rock Crawler Join Date: Jun 2007 Location: oVER ThErE
Great Job...
06-11-2007, 11:10 PM | #59 | |
Your chassis looks better everytime I check back on this thread so I gotta ask a bunch of ?'s in one reply so I wont make myself rebuild my turd outta envy. | |
06-12-2007, 04:44 PM | #60 | |
Thanks for the positive comments! Quote:
