12-03-2012, 10:06 PM | #61 |
Rock Crawler Join Date: Jan 2008 Location: Lincoln
| Re: Hey, look. Another jeep!
Not a ton of updates for this guy, but I've been able to properly mount the transfer case, make some front shock mounts that are a little more stable, and generally tried to smooth everything out so the suspension can cycle properly. One thing about using these hybrid axles- I'm kinda surprised how much noodling I have to do to get these things to work without binding up, and I was hoping to use a set of barely used losi shocks, but they're just too damn big. The stock scx10 shocks should work fine, but I was hoping for a little beefier shock to help handle the weight of this pig. Added a little aluminum for the front shock mounts.(paint should hide these nicely.) Beefier skid for the t-case- need to counter-sink these buttonheads. Playing around with the front steering arm. It's good clearance, but I need to make some better 1/8 inch connecting plates. That's about it for now. I'd love to get a bunch of parts for this thing, but I'm just a lot broker than usual. My unemployment's run out and work I did have dried up, so I have to either make it myself or do without. But it's getting there. |
12-04-2012, 06:42 AM | #62 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
sorry to hear about the lack of work, but the jeep is looking great!
12-04-2012, 08:54 AM | #63 | |
| Re: Hey, look. Another jeep! Quote:
Nice work on the AXR-10 axles! | |
12-04-2012, 06:57 PM | #64 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
If you move those shocks farther forward like straight up and down you will get better clearance. If you haven't tried this yet but some wide hubs that might help a little. I used g transition 1/8 scale shocks and they clear on my rig. My Willy's is 14.5 lbs and the 1/8 scale in droop works very well and looks like a shock. Just a few ideas looks good love.the Willy's builds they crawl so realistic
05-24-2013, 09:18 PM | #65 |
Pebble Pounder Join Date: Dec 2004 Location: Pollock pines
Any Progress?
03-25-2014, 01:40 AM | #66 |
Wow, it's been over a year since I really worked on this thing. Finally a friend of mine threw down the challenge, and whether this thing is "perfect" or not, it has to be at least moving under it's own power by the end of April. I have an old r2 tranny with a fresh set of gears- this might do until I get get an Axial trans together. My problem right now is the steering servo, anybody figure out a good mounting location? I could lay it down on the bottom plate in the front, but it seems a little vulnerable. Standing the servo upright basically means I have to hack into the radiator. How did you guys deal with this? |
03-25-2014, 10:26 AM | #67 |
Pebble Pounder Join Date: Nov 2010 Location: Northern NJ
[QUOTE= My problem right now is the steering servo, anybody figure out a good mounting location? I could lay it down on the bottom plate in the front, but it seems a little vulnerable. Standing the servo upright basically means I have to hack into the radiator. How did you guys deal with this?[/QUOTE] Stand the servo up so it mounts just behind the radiator, inside the engine compartment. That is Std mounting position for a Hasbro Willys Build. |
03-25-2014, 09:35 PM | #68 |
here's the only pic I could find of the servo mount location on my Orange Jeep. |
03-25-2014, 11:36 PM | #69 |
Thanks guys, this gets the gears turning again. I might have to cut into the radiator, but it should'nt be too bad. I might just trim off the front bumper for more clearance.
04-11-2014, 11:12 AM | #70 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
Just checked in on this, and must say, it looks great! If you haven't already dealt with your steering servo, you might try using a bell crank mounted in there and then place the servo any where you want. That's what I'm doing on my CJ(which I haven't touched for quite some time). It's also more scale since that's how the steering was set up on the real deal.
04-11-2014, 04:39 PM | #71 |
Rock Crawler Join Date: Feb 2012 Location: Wisconsin
| Re: Hey, look. Another jeep! |
04-11-2014, 08:18 PM | #72 | |
04-11-2014, 10:10 PM | #73 |
| Re: Hey, look. Another jeep! I ended up cutting back my front bumper too, then made a stinger for it. I like it much better being shortened up like that.
05-11-2014, 06:59 PM | #74 |
| Re: Hey, look. Another jeep! You will need to fabricate a panhard bar mount to get everything to clear. it will take some work, welding (or brazing), and lots of patience. Seach the forum for photos to get ideas on the layout.
01-03-2015, 01:58 AM | #75 |
Wow, I cant believe I started this thing 3 years ago.... I kept running out of money (and occasionally ideas) but I stuck with it , and now for 2015, It RUNS! Yay! I'll have a little run video to post up tomorrow, it has a few little test runs in the yard to find the gremlins, but she's a runner! These are really fun to drive! I was finally able to pick up an all-metal transmission, a 2800kv Roc412 and a mamba. I've got a lot more work to do yet, but I'm real happy with how it sits now. |
01-04-2015, 10:05 AM | #76 |
Here's a vid of the maiden voyage.... |
01-05-2015, 12:21 PM | #77 |
Pebble Pounder Join Date: Feb 2009 Location: Augusta
That cage is a work of art. Damn nice building.
01-05-2015, 06:38 PM | #78 |
Quarry Creeper Join Date: Sep 2010 Location: where ever I layed my hat.
Another monster is alive, great work. Curious to what your esc settings are. I am running a similar set up to yours and my down hill control is lacking where it feels like it is coasting more than any thing. |
01-05-2015, 07:17 PM | #79 |
I'm trying so badly to rebuild mine this winter, including a new cage. It sits more than it gets used, I want to change that.
01-06-2015, 06:02 PM | #80 |
Do the Rock Beasts have a stiffer sidewall than Super Swampers, or are you using stiffer foams?
