07-08-2013, 02:15 PM | #21 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: derstine's willys
got it split... bout 4 dremel cutoff wheels, and when i almost burnt out the dremel it was the last 3" by hand holding the hacksaw blade with not handle. will get pics later, going to braze it all together tonight. |
07-09-2013, 07:56 AM | #22 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Re: derstine's willys Quote:
At least you know when to quit! I gave up on Dremels, I'm too tough on them I guess. I'll melt the brushes every time I use one for heavy work like that... | |
07-09-2013, 08:32 AM | #23 |
Good progress! As tough as the stock plastic chassis is, I'd do another steel frame in a heart beat. It just sounds so darn cool when it drags over some rocks. |
07-09-2013, 09:04 AM | #24 |
RCC Addict Join Date: Jun 2006 Location: Maryland
Next time you need to split one, hit me up. I have a band saw.
07-09-2013, 10:10 AM | #25 |
| Re: derstine's willys |
07-09-2013, 11:11 AM | #26 | |||
planning to make the cross members as real as i can without making it too hard to braze them on. | |||
07-09-2013, 09:51 PM | #27 |
well got the frame brazed together. front has the start of a servo mount. got a little jib worked up with rulers, and magnets. its not as good as some things i have seen from BigSki's shop, but it works for me. measure measure measure measure measure. then it finally worked. the got to work on the rear bumper. but a piece in half the long way, again. and bent up the ends to kinda match the stock plastic one. cut some slots to bumper for the frame rails to come through where i will be able to mount some d-rings. whole thing lined up perfectly with the stock frame too. and lines up with all the lines of the body. i left the front about 3" overhang incase i plan to have a longer than stock wheelbase. which i plan to do. that way i can mount a cool bumper or something up there. here are the pics. |
07-10-2013, 08:45 PM | #28 |
playin around with some wheelbase and tire options. kinda like the pits on here. they work out to 34.5" scale tires. lots to do here still. also brazed a couple things on the chassis. ran out of mapp so gotta get some more tomorrow. but the angled braces are on like the real one. and put the rear body mounts on and drilled the holes. just gotta do the ones for the front tomorrow. first two pics are what i am going for at the end for looks. also like that orange one too. might be a mix of both. what kinda wheel base are you guys making? |
07-11-2013, 07:21 AM | #29 |
| Re: derstine's willys This chassis is really coming together...
07-11-2013, 03:51 PM | #30 |
Pebble Pounder Join Date: Apr 2009 Location: Whitehall,Maryland
Nice frame. Can't wait to see this thing.
07-11-2013, 04:10 PM | #31 |
Quarry Creeper Join Date: Apr 2009 Location: San Diego,CA
Nice, making some progress I see.
07-16-2013, 11:00 AM | #32 |
yup. what kinda wheel base are you guys going with? |
07-16-2013, 03:38 PM | #33 |
07-16-2013, 04:07 PM | #34 |
ok, i think i am just gonna wing it. probably come in around 13" or something like that. thanks man! |
09-29-2013, 06:09 PM | #35 |
havent really "done" anything, but am getting lined up to get the rear axle on. gonna be using my twin force 8.25" width axles. i think i am gonna have some rubbing up front with them. but i should be able to alter some things to get around that. rear is gonna be leaf sprung. still need to decide if i want or need anti-wrap bars, but i probably will. really want to see if i can get both axles all ready to go by friday. want to take it up to BobRocks in MD this coming weekend. |
09-30-2013, 11:48 AM | #36 |
BobRocks is comin' up quick make it happen man!! Lookin' good! |
09-30-2013, 01:05 PM | #37 |
ordered my silver solder this morning. its priority mail so might get it wednesday or thursday at the latest. then its just fabbing up the motor mount, transfer case mount, linke mounts, front bumper. should be able to fab some of those things before the brazing stuff comes in. then it should just be turn the torch on and go.
09-30-2013, 09:52 PM | #38 |
got the transfer case mocked up. need to get the mounting tabs for the links done tongiht. gonna have to to some cutting for the t-case to fit. but won't be noticeable after some styrene work. also need to mock up the transmission mount under the hood. Last edited by mjderstine; 10-01-2013 at 07:40 AM. |
10-04-2013, 07:16 PM | #39 |
i want my solder. it didnt come in. ordered it monday. priority. from holmes. bummer.
10-07-2013, 08:19 PM | #40 |
derstine's willys - Similar Threads | ||||
Just another '41 Willys | Jester666 | Large Scale Rigs | 6 | 03-16-2012 08:12 PM |
Willys | ZoSo | Scale Videos! | 6 | 07-29-2011 05:28 PM |
1:6 Willys | ZoSo | Scale Videos! | 5 | 10-11-2009 08:37 PM |
'41 willys | NeXt559 | Paint and Body | 11 | 09-19-2008 05:35 AM |
