02-24-2023, 07:26 PM | #1 |
| scx6 honcho from scratch
my honcho body shipped today im planning on a complete custom tube chassis this will be a slow build cause these aint cheep but ill document my costs and try to build it as cheap as possable and still use in my opinion good parts the only axial parts im planning on using is the body set and there skid plate and maybe a few cosmetic parts so body was 160+ ill say 175 after tax and shipping |
02-25-2023, 07:56 PM | #2 |
| Re: scx6 honcho from scratch
so ill add another $100 for the aluminum 2peed transmission and $15 for a axial skid plate that puts me at $290 so far |
02-25-2023, 08:34 PM | #3 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Interested in seeing what you do here Scx6 honcho is on my short list of rigs to buy Sent from my iPhone using Tapatalk |
02-25-2023, 09:08 PM | #4 | |
| Re: scx6 honcho from scratch Quote:
im interested to see how it comes together too this is gona be fun | |
02-26-2023, 04:13 PM | #5 |
Quarry Creeper Join Date: Jun 2015 Location: Lancaster, NY
Definitely interested to see what the total ends up being. At least this way you can pick and choose what parts and electronics you want to put on it. If it came in kit form I’d be all over it.
03-03-2023, 10:53 AM | #6 |
damb the transmission is huge and heavy it must weigh 10lbs by its self i thought it was a battery for my solar system but nope it was the scx6 trans holly poop i should have my body today hopfully fed-up dosent ruin it in shipping |
03-20-2023, 02:11 PM | #7 |
Rock Stacker Join Date: Oct 2019 Location: Coastal South Jersey
Big Honcho fan will be following. Btw read your subbie build in the 1:1 section- good stuff! |
03-21-2023, 05:36 PM | #8 |
| Re: scx6 honcho from scratch |
04-04-2023, 06:59 AM | #9 |
Pebble Pounder Join Date: Feb 2022 Location: Batam Island, Indonesia
Look the SCX6 only as a rolling frame , how cool is that for the builders out there, i do dislike the colour € 711,24 30%OFF | 1/6 SCX6 Car Frame with Gearbox Wheel Hub Tire All-metal Chassis Remote Control Car Model Simulation Climbing Upgrade Car Kit https://a.aliexpress.com/_m0nX6R6 Sent from my CPH1937 using Tapatalk |
04-04-2023, 08:36 AM | #10 |
04-04-2023, 04:04 PM | #11 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
Slow progress, is still progress. I have a couple builds that seem to have been shelved for a couple years... Some times, real life, or other projects get in the way. It is hard to tell from the pic, but what are you building the chassis out of? |
04-04-2023, 09:38 PM | #12 |
the parts cost so much its hard to put to much effert in to it but as parts come in i get alittle motivation to work on it lol and i spend alot of time staring at it trying do design it in my head before i make it im using 1/4 inch steel rod recycled from some kind of shelf unit so im saving about $150 by making my own cage from scraps and not buying the frame rails or the bed cage Last edited by ferp420; 04-04-2023 at 09:40 PM. |
06-12-2023, 07:39 AM | #13 |
Axles should be here in a day or 2 then i need some drive shafts so i can set the wheel base and that will tell me were to place the skid on the chassie then i can start welding up the frame and rear cage Praticing my body painting on some cheap bodys to make sure i got it down enuff to not screw this one up Im missing the electronics still but have just about everything else so once i get some shafts it should make alot of progress pretty quick Axles + $150 "yup the cheapest complete axles i could find " so that puts me at about $440 as of right now Last edited by ferp420; 06-12-2023 at 07:48 AM. |
06-19-2023, 02:10 PM | #14 |
07-04-2023, 09:24 AM | #15 |
I got the inside of the body painted the provided masks suck so I used masking tape but I did use them on the lights and sure enuff I got some bleed though not to big of a deal but kinda bummed me out The front fenders I painted white to give that fiberglass fenders look when the paint scratches The rest of the cab I used a vary light coat of silver and backed it with some gray primer it's not vary uniform but it's a underlayment and will look just fine under the scratches |
07-05-2023, 10:34 AM | #16 |
Quarry Creeper Join Date: May 2023 Location: Hungary
very cool build those huge axles must weight some? great have alot weight down low |
07-06-2023, 12:59 AM | #17 |
Scratch builds are the coolest with alu axles, many times better than the original plastic rigs. If you can weld, then do own custom builds only. RTR Kits sucks many times. My issue is that i can not weld, and i dont have weld machine :( If i had, i would only do scratch builds. My current dream is build one custom scrats TRX4 +size. stock is 324mm wheelbase i believe. My dream is Make one 360mm and have 4wheel steering = two front axles, front x2 alu axles with remote locks. Portals and huge 2.2 wheels Cab only body Ferp420 you live in huge area, this 1/6 Scale will be nice to you, you need some huge size there |
07-09-2023, 08:47 AM | #18 | |
Anyway the drive shafts showed up in ordered 2 sets cause I want a longer wheelbase than stock so I bought a extra set to make a extra long shaft then I can set my wheelbase were I think it should be and start on the cage I'll post pics as soon as I have something to take pics of lol | |
07-09-2023, 06:56 PM | #19 |
07-10-2023, 10:30 AM | #20 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
Ha! White, fiberglass fenders. A true southern California offroad rig. Some Ford Ranger badging would top it off.
scx6 honcho from scratch - Similar Threads | ||||
SCX6 Trail Honcho Christmas 2022 | AK KRAWLER | Large Scale Rigs | 17 | 01-14-2023 08:50 PM |
SCX6 Trail Honcho | FastMatt | Large Scale Rigs | 24 | 11-18-2022 06:35 AM |
First session with SCX6 Honcho after its facelift | chilly | Videos! | 0 | 11-15-2022 10:05 PM |
Scx6 honcho - can’t by main lexan shell alone? | chilly | Large Scale Rigs | 6 | 11-14-2022 07:04 PM |
Holy moly I bought a SCX6 Honcho! | chilly | Large Scale Rigs | 7 | 11-07-2022 06:32 AM |
