04-26-2010, 04:13 PM | #121 |
Got mine in today and got it installed.....one thing to note is the leafs are different front to rear. You have to make sure that you have them in the correct place or the front axle will be clock down. I found out the hard way. Also anyone got any pics on hooking the drag link back up to the stock servo and arm? I have the servo mounted in the top and forward most holes. All-in-all great looking chassis....haven't got to drive it yet. |
04-26-2010, 06:35 PM | #122 | |
Rock Stacker Join Date: Feb 2010 Location: Portland,OR
04-26-2010, 08:32 PM | #123 |
Quarry Creeper Join Date: Sep 2005 Location: Canon City
Not a stock servo or horn, but you can kind of see how I did mine in this shot...... Thats a arm that came with the servo(HS-65). It clears the bottom of the chassis. If you need some more shots of it for ideas on yours let me know. |
04-26-2010, 10:56 PM | #124 |
Quarry Creeper Join Date: Jan 2004 Location: Long Island NY.
just a quick question. When you install the leafs onto frame do you tighten them down or leave them loose enough to move around when the suspension articulates??
04-26-2010, 11:27 PM | #125 |
Quarry Creeper Join Date: Jun 2004 Location: Utah
04-27-2010, 11:53 PM | #126 |
I've cured all the axle rap in the rear using the stock shocks. Used the spacers for the servo mounts on the axles leaf mounts the push out the leafs a bit. turned all the spacers on the bolts around aswell. a long bolt from the stock losi kit run threw the screw hole that holds the shock cap on and a small cross brace made from some styrene. |
04-28-2010, 02:52 PM | #127 | |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
04-28-2010, 08:24 PM | #128 |
04-28-2010, 08:47 PM | #129 |
Rock Stacker Join Date: Jan 2009 Location: glengardener
Use the stock lower links or fab ur own all the ball studs are still there
04-30-2010, 10:30 AM | #130 | |
I'm using links on the front axle but I got this frame to put under my ext cab silverado and having big long lower links on the back wasen't very scale looking for me. | |
04-30-2010, 12:02 PM | #131 | |
04-30-2010, 01:34 PM | #132 |
04-30-2010, 03:10 PM | #133 |
Ratboy99 Your truck is looking Awesome good job! Blade |
05-02-2010, 02:40 PM | #134 |
Pebble Pounder Join Date: Feb 2010 Location: Canada
what scales could i put on this chassis and would i have to extend the drive shafts?
05-02-2010, 03:01 PM | #135 | |
Thanks Blade | |
05-02-2010, 08:09 PM | #136 |
Just wanted to share a few things I found with this chassis to make it perform a good bit better. I found using the BWD wheel weights it helped a TON in allowing the truck to flex. But I knew it had more so I put lead shot in all 4 tires without foams and the extra weight really helps the chassis out ALOTTT. It helps all the tires stay planted when flexing. and definetly alows the leafs to work much better and stops some of the springyness. But other than that I think this thing is spot on. |
05-03-2010, 09:30 AM | #137 |
05-03-2010, 09:58 AM | #138 |
Rock Stacker Join Date: Jun 2007 Location: Abbotsford BC
05-06-2010, 08:09 PM | #139 |
Pebble Pounder Join Date: Mar 2010 Location: Crest Hill
I got my chassis today and it looks great. I have a great looking H2 body that i'm hoping fits just right. I've even made a bolt on drop trailer hitch. Pictures soon to come.
02-18-2011, 05:10 PM | #140 |
Newbie Join Date: Feb 2011 Location: AZ
| help me plz
a blade how do i put it together i got the kit in the mail but i cant build it help me plz
