03-23-2016, 02:46 PM | #21 | |
Newbie Join Date: Mar 2016 Location: Detroit
| Re: ECX 1/24 Temper Quote:
03-23-2016, 04:46 PM | #22 |
Rock Stacker Join Date: Mar 2016 Location: OK
| Re: ECX 1/24 Temper
Yes. In fact the rc4wd 1/18 D90 uses the exact save combo rx/esc and tx, and comes with a 2S lipo in the box.
06-14-2016, 05:51 PM | #23 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: ECX 1/24 Temper How do you know that? If it's the case then it should have lipo cutoff like the D90. But I think you're thinking of the 1/18 scale ECX Temper, not the 1/24 scale that's being talked about here... I could be wrong.
06-17-2016, 08:10 AM | #24 |
| Re: ECX 1/24 Temper
Indeed you are. I know because I have owned both. The radios and esc's are identical except for the D90's TX being molded from a different color of plastic. The D90 esc dies not have any sort of lipo cutoff... They simply throw a lipo voltage checker/alarm in the box.
06-17-2016, 09:46 AM | #25 |
| Re: ECX 1/24 Temper |
06-17-2016, 09:49 AM | #26 | |
06-17-2016, 10:04 AM | #27 |
| Re: ECX 1/24 Temper
So I just picked up a lot of 4 used for $150 that had only minor issues. After replacing broken parts ($10 driveshaft and $7 steering spindle), they work great. The steering DR needed turned down to prevent the wheels from binding when moving forward or backward. :( I plan to solve the articulation issues by removing the shocks and upper links and replacing them with a torsion (do a search if you're unfamiliar) setup using piano wire. If the axles still walk side to side then I will drill the tranny mount and move the bottom links further toward the center using a long bolt and nut, and possibly 2 correctly sized and drilled crafting beads. If the driveshaft porcupine ball pins break, I'll replace the pins with a piece of paper clip glued in. I picked up 2 scale bodies at Walmart for $8 in the toy section and plan to add delrin or aluminum chassis rails to mount them. Should I make a separate build thread or try and keep all the info centralized here? |
06-17-2016, 01:40 PM | #28 |
| Re: ECX 1/24 Temper
You're welcome. Sounds like you've got some fun projects. Mine has now been built into a Specter project. Which reminds me, watch out if ordering ball links because they are not the same size as the losi ones.
06-18-2016, 08:38 AM | #29 |
| Re: ECX 1/24 Temper Thanks for the tip. I also noticed the ecx ball studs must be purchased with a full hardware set for about $20 while the losi are available separately for $5.
ECX 1/24 Temper - Similar Threads | ||||
ECX Temper scale test and tune | jj650 | Losi Mini-Rock Crawler | 60 | 01-06-2019 09:17 PM |
ECX Temper | spectre | Losi Mini-Rock Crawler | 30 | 01-03-2017 11:59 PM |
Ecx temper upgrades | rehnjames | Losi Mini-Rock Crawler | 4 | 01-06-2016 03:40 PM |
ecx temper upgrades starting tomorrow hopefully | Chewitt214 | Newbie General | 19 | 12-28-2015 06:44 AM |
Ecx Temper | mactools02 | General Crawlers | 2 | 12-28-2015 06:39 AM |
