Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Wider rims? O.o
Old 02-24-2017, 05:59 PM   #1
Default Wider rims? O.o
I'm thinking of adding some wider rims options. This is a stock offset old army jeep style rim that has been widened 1/8". I will also do the 1/8" and 1/4" offset versions. You can also wrap a lot of copper wire or solder to add weight. Any interest?
Fungi is offline   Reply With Quote
Old 02-25-2017, 04:09 PM   #2
Default Re: Wider rims? O.o
They are here.
Old 02-26-2017, 11:16 AM   #3
I added the full set of offsets.
Old 02-26-2017, 11:56 PM   #4
Any pics of what the tire would look like mounted on wider wheels? Also, what kind of paint would you recommend for these? Thanks
LiqrSicc is offline   Reply With Quote
Old 02-27-2017, 08:06 AM   #5
I just drew these rims, so they haven't been printed yet. I made the rims specifically for the Rock Creeper tire, but the Rok Lox would also do well. Well, any tire attached to this rim will have slightly more surface area on the flat, and the sidewalls will be pushed out for a slightly wider stance.
Wider rims? O.o - Similar Threads
Offset hex... for a wider a wider stance. Willy Smellson Axial Wraith 2 01-30-2013 04:26 AM
Wider is better? Slowbro Chit Chat 16 01-08-2013 11:20 PM
rims thatll give the truck a little more wider stance bro_die Tires and Wheels 4 07-04-2011 07:10 AM
Is wider better? jimmy1969510 Newbie General 3 12-09-2007 03:00 PM
WIDER SupermanWV Tamiya Clod Buster 7 09-24-2004 04:10 PM
