11-19-2010, 03:00 PM | #41 | |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
11-19-2010, 03:23 PM | #42 |
| Rear end sorted
A night of mixed emotions. Some bits went better than expected whilst other bit were really frustrating. My goal was to beef up the rear end further. Other have said about shimming the diff and there was play there so I put one shim on each of the out side of the out drive bearing and this did the trick. I then nut and bolted the axle case to clamp the case better, the nut is prevented from turning whilst tightening by being butted up against the diff case. Lucky, as it's a mighty small nut and I ain't got a 2mm driver. I then drilled the stock BWD delrin chassis brace to accept the stock MRC body mount vertically. This was drilled to 2mm and the fit was great. I was going to, and still might drill it to 3mm and use Axial plastic body mounts but these will do for now. So far so good. But then the frustrations. I wanted to outboard the rear shocks and I also wanted them further out from the chassis to keep the shocks at 90% to the axle, or as close as I could get so I bought 25mm M3 bolts and put a lock nut behind the spacer - great. Then I bolted both sides into an 18mm Hot Racing threaded aluminium spacer. All very neat, but then I came to outboard the shocks at the axle but there was no room as the single piece rear axle shroud prevented this.... So I took the shocks off again, removed the lock nuts to bring them back closer to the chassis and bolted them back on adding a couple of washers either side of the chassis brace. Had a break to update the thread only to realize that I was trying to outboard the shocks on the lower links mounting point..... So I'm now off to do it all over again. (Must get more sleep). Enjoy the pics Last edited by neiloid1; 11-20-2010 at 01:39 PM. Reason: spelling |
11-19-2010, 04:09 PM | #43 |
| All sorted now
Rear end all back together, but pride is in tatters But I think it works Also replaced those bloody awful countersunk hex head bolts that round far too easily. Has anyone drilled the servo plate mounts to 3mm??? |
11-19-2010, 05:36 PM | #44 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Glad it's not just me that has mixed results with the MRC Not to sure you want the shocks straight though mate, tried it on mine when i was messing with adjustments and found the side to side stability suffered. If the shocks are facing straight down to the mounts then when the truck is tilted instead 1 side compressing the other extending, both will be extending and twisting if that makes sense. How did you get the bolts on the axle cover? Tried that on mind and they wouldn't fit, i would have had to dremel the inner cover. Tell your Mrs to take that fooooooking drill from your hands and hide it, you've done the steering mod and now you've gone 3mm crazy Can't see any advantage in doing the servo plate bolts 3mm though, the 3 x 2mm bolts are plenty plus drilling it out to 3mm means there is less material around the screw so it'll be weaker if anything. You done any driving with the overdrive mod yet? Thoughts? Cheers Mark |
11-25-2010, 12:52 PM | #45 | ||
As for the overdrive mod I'm still waiting in the CVDs before I crack open the front axle again so I can do it \all in one go and be done with it. | ||
11-25-2010, 01:09 PM | #46 |
| G-Made wheel wideners
Sat here waiting for my 6mm drill bit to show I looked at the Losi wheels and thought that the actual amount of material to be removed was next to nothing. So with a bit of trepidation I started to ream the axle hole with my body hole reamer and to my delight the aluminum started to shave off. Checking the hole against the wheel widener bolts I was able to remove just enough for a nice snug fit. The wheel wideners added to the front gives a slightly more aggressive stance and adds a dash of color. Last edited by neiloid1; 11-30-2010 at 08:29 PM. |
11-26-2010, 04:15 AM | #47 |
Jobs a good un |
01-01-2011, 01:19 PM | #48 |
| Zero Ackerman
At long last the build is complete. I got aluminium zero ackerman knuckles installed, then had to extend the BWD OTA steering to accomodate the shorter steering arms, installed the Losi CVDs and I'm good to go. A picture of how the front ended up. |
01-01-2011, 01:58 PM | #49 |
| Full spec
So the final(?) build spec - Billet Work Designs Mini Wedge Chassis BWD OTA steering mod, extended for zero ackerman steering BWD motor plate Losi stock crawler motor rewired with bullet connectors Losi stock transmission with steel diff locker Losi drive shafts with shrink wrapped pins Losi metals diffs lockers front and rear Losi one peice rear axle with Losi metal Hexs Rear axle case bolt through with M2 nut & bolts BWD servo plate on the rear axle for battery placement option Losi Front CVDs with shrink wrapped pins G-Made axle wideners Losi alumium Cs with M3 button bolt mod Losi aluminium zero ackerman knuckles Traxxas overdrive mod Front axle case bolted with M2 nut and bolts Losi aluminium shocks with 35 weight oil all round Losi blue springs, black right rear Extended shock mounts braced front and rear with HR aluminium spacers Outboarded shocks front and rear Hitec HS5955TG servo Ansman aluminium servo arm HR aluminium servo mounts Losi aluminium beadlocks Standard weights front No weights rear Crawler Innovations Stage 1 soft foams up front Crawler Innovations Stage 1 medium foams in the rear Losi blue Rock Bashers Castle Creation Sidewinder ESC Castle Creation BEC Spektrum Receiver Spektrum DX3S CBP Elite 2S 850 Standard shell whilst I wait for my bug body to be trimmed and painted. Future spends - Mini Torque Master, Rovers, MIP drive shafts and heavier Losi front wheel weights. 'Proper' pictures of the completed build to follow. Maybe even a vid if I can persuade the boy to hold the camera. Spent a long time choosing the chassis and on this build. It's been a joy to put together and the support and info I've got from the forum has been invaluable. Hopefully my patience will be rewarded. Hope it meets Don's approval. Now to hit the rocks and dial her in. Last edited by neiloid1; 04-12-2011 at 03:58 PM. |
01-01-2011, 03:47 PM | #50 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
You'll be amazed as to what this little chassis can do. Glad you're back among the living. |
01-02-2011, 02:52 PM | #51 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
Your rig looks great . Hope to do some crawling with ya soon! That beast is beggin to be on the rocks |
01-02-2011, 04:44 PM | #52 |
Newbie Join Date: Aug 2010 Location: Fleet Hampshire
nice build very impresive so where do you crawl in hampshire ??? |
01-03-2011, 09:37 AM | #53 |
01-03-2011, 09:45 AM | #54 |
01-03-2011, 01:25 PM | #55 |
have you tried the sea defence in gosport very good for crawling where the green ferry lands been there a couple of times. Have also been told there is good crawling at langstone near southsea marina |
01-04-2011, 02:01 AM | #56 |
| Thanks for those suggestions, I live 15 minutes away from Langstone so that'll be first port of call this weekend. Not been to Gosport but I'll be checking that out too |
01-04-2011, 09:09 AM | #57 |
Good job on adapting the knuckles mate |
01-04-2011, 09:19 AM | #58 |
| Cheers, I put a 20mm length of all rod in both rod ends and took up the gap with nuts and washers to add a bit of strength to the proceedings. I got it all back together and had bad bind. Thought it might have been the CVDs or not recessing the servo post bolts enough but it was the OTA steerer catching the front half of the axle casing. So took it all apart and filed it smooth and added spacers between the steering arms and the knuckles to raise the steering arm clear and the jobs a good 'un. Found the new rear link plate on the BWD site so may well spring for that and the proper ZA OTA link, but first I just want to get a good few hours getting it dialed first. Last edited by neiloid1; 01-04-2011 at 09:22 AM. |
01-04-2011, 10:13 AM | #59 |
Did you countersink the servo mount holes while you were at it?
01-04-2011, 06:06 PM | #60 |
