01-24-2011, 02:10 PM | #61 |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
I got problems CC Sidewinder woes need a fix now the weathers getting better and the days are getting longer. Thanks in advance. |
04-16-2011, 08:31 AM | #62 |
Little update. The ESC woes are sorted and I have reverse, so I've now got the electronics strapped in. The receiver will get the on/off switch servo taped to it. Made a lexan mount for the ESC and BEC. |
04-16-2011, 08:38 AM | #63 |
Although there is very little to no torque twist in normal use I added a pen spring to the rear left to limit travel and the improvements are worthwhile, will look at limiting the travel of the front shocks, though not too worried at the moment. http://www.youtube.com/watch?v=Xzx0fqCmE7U&NR=1 http://www.youtube.com/watch?v=KhyRB...eature=related http://www.youtube.com/watch?v=9xw3PH4kM0I http://www.youtube.com/watch?v=GejYOc_GnDs Not great but taken on 3GS whilst I was at the controls too. Elite 850mah 2S on the rear axle. Getting great run times out of this cell whilst testing in the back yard. Highly recommended lipo. Just need to add the bug body to add this finishing touch and give a bit of protection. Great fun building this rig but driving and fine tuning it is even more fun, I'm hooked. Last edited by neiloid1; 05-02-2011 at 03:28 PM. Reason: YouTube links added |
04-16-2011, 12:36 PM | #64 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
measure ur front end with the g made spacers i had to shave alittle off both sides to stay within the 8in comp rules also i drilled the cvds to 2.2 pins hope this helps you looks great on the build |
04-16-2011, 01:54 PM | #65 |
Thanks Thomas, not heard of the 2.2 cvd pin mod, that leaves enought metal round the pin? As far as the width goes I couldn't give a hoot as comps in the UK are rare as rockin' horse shit - if I ever were to then I'd just stick on me Losi aluminium hex's. I'm at 8.25 with the G-made hex's. I'd not even considered measuring the width, so thank you.
04-21-2011, 02:31 PM | #66 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
WOW and i thought i crammed alot into mine LOL. looks good man
04-22-2011, 09:38 AM | #67 |
i broke a cvd but not at the pin so seems to hav enough metal left i just didnt want any play at the pin with the 1.9 pin it had the smallest amount of stall mayb u wont notice it but bigger pin equals more strenght n no more bent pins haha
04-22-2011, 10:04 AM | #68 |
so does the 2.2 CVD pin fit right in the 1.9 CVD hole?
04-22-2011, 10:31 AM | #69 |
yes i believe it does fit tight, guys in my club are running MRC inners with LCC stubs with no mods, if i recall correctly
04-22-2011, 11:03 AM | #70 |
Sounds like a plan - how you liking your bodiless set up? Did you go for the thicker of the two on offer and how is it for righting after a roll. I've got a beatle body being painted up but I reckon bodiless may be a better option as my stocker cutaway shell was a real pain today. Just happy that Don offers the option as it saves building a whole new rig. Got anymore pics of your bodiless mini wedge? |
04-23-2011, 10:24 PM | #71 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
Looks good Neil. It's fun shoe-horning everything into that chassis. As for the CVD mod, I believe you need a couple 5x8mm id/od bearings to make it work.
04-24-2011, 07:14 PM | #72 | |
heres all my pics of the topper | |
05-05-2011, 12:34 PM | #73 |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
This thread has helped me alot I'm in the process of gettin a MRC together for my girl and the mini wedge is the chassis I'll be working with for sure. Thank you for taking the time to document everything You've got a great looking rig there! |
05-05-2011, 01:16 PM | #74 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
05-05-2011, 02:09 PM | #75 |
| Thanks chaps - appreciated.
Thank you both for your kind words, it's been a pleasure documenting the build and I'm glad you both found it useful. Next on the list the a better motor, BWD Dub Topper and the Proline dub body (which my brother has for painting - and has had for the past 6 months ), etc...... Pics and video to follow - love driving this rig and I'm sure you will too. Any questions just feel free to contact me. |
05-13-2011, 07:27 AM | #76 |
| Small update
Got the heavier rim weights for my Losi aluminum beadlocks through. Gone are the shiny weights that come with the wheels to be replaced with these industrial looking lumps. Added 30 grams to each wheel (1oz) giving an all up weight of 7.4ozs per side up front.
05-13-2011, 07:40 AM | #77 |
| and
I also fabbed a new rear 4 link whilst waiting for Don to get back to me after a chat with Rick M. Took the stock rear link plate and took a hack saw to it. Attached the stock lower links with 3mm hardware either end and 20 minutes later this is the result. Hardly a thing of great beauty but it gives me the chance to assess the longer rear links set up for free. |
05-14-2011, 12:10 PM | #78 |
Good job on the rear link plate and longer links. How is the geometry and articulation with this new set-up compared to the original BWD set-up?
05-17-2011, 07:22 AM | #79 |
do yourself a big favor and chop out all the wiring. my mamba 25, futaba rx and bec all fit inside the chassis with battery on the rear axle.very clean looking. love the hell out of my mini wedge now. ordered a black DUB topper. cant wait!!! |
05-17-2011, 02:30 PM | #80 | |
Just waiting on pictures from RickM.... Any reason for the black over white Dub topper? | |
