01-12-2014, 01:21 PM | #1 |
Newbie Join Date: Oct 2012 Location: SATX
| Problems with LOSI MRC steering geometry?? Help!?
Whats up guys, After upgrading my servo to the hitec HS-646WP my steering is not centered.. It turns a little more to the right then it does to the left. Will this superlift Adjustable steering stabilizer work to fix this? It says that you can use it as a steering linkage on the site. If not, can anyone point me in the direction to fix this? Thanks in advance, Mike Last edited by mike253905; 01-12-2014 at 04:02 PM. |
01-12-2014, 01:29 PM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: Canada
| Re: Problems with LOSI MRC steering geometry?? Help!?
unscrew your steering arm from the servo power up the machine servo will center now re-attach your steering arm centered on the splines of the servo adjust your steering linkage so your wheels are straight done |
01-12-2014, 04:01 PM | #3 |
@daver18qc Thanks for your response. Here is a picture of my servo horn on.. I think the problem is that after adding the 1/10 servo to it the servo is a little further towards the right side of the car and the short steering linkage cant reach with my servo horn at complete center so I am forced to have it the way you see in the pic.. Do you see any easy fixes? I'm new to this so it might be something simple but I cant seem to figure it out. I've used it for the past couple of months the way it is but am now starting to get tired of it turning more to the right then to the left.. especially with crawling every small move counts.. thanks again |
01-12-2014, 04:27 PM | #4 | |
| Re: Problems with LOSI MRC steering geometry?? Help!? Quote:
That is, do that after you center your steering arm (circled in blue) on the servo so that it points straight down and not a little to the left like it is in the picture ! You need a steering link (circled in red) that looks like this and that you can adjust : What you can also do, on the cheap, is cut your link in half and use a piece of threaded rod or a long screw that you cut the head off to screw both halves back together, leave some space in the middle so that you effectively have more length. Last edited by daver18qc; 01-12-2014 at 04:35 PM. | |
01-12-2014, 06:43 PM | #5 |
@daver18qc, Can you point me in the right direction for a adjustable steering link that will work for the mrc? The only one I see is the superlift steering stabilizer from rc4wd but it says it can be used as acc adjustable steering link. But it's like 12-14$. Is there any cheaper options? |
01-12-2014, 07:47 PM | #6 |
The cheaper option would be to go to your local hobbie store and look for ANY make/model link that would fit your application. An Axial SCX10 steering link would probably fit, with some tweaking from a metal saw or dremel tool. If that is not possible then fix your steering arm to point straight down, point your wheels straight ahead and measure the distance needed for the link. Then you can buy something on the internet that fits. |
01-12-2014, 08:13 PM | #7 |
Pebble Pounder Join Date: May 2006 Location: willows
Try putting your link at the lowest point on the servo arm. It may give you the extra bit you need.
03-07-2014, 09:34 PM | #8 |
@denno yo man, I just got around to trying your advice of lowering the link to the bottom hole on the servo arm. It worked like a charm! Thanks again bro!
Problems with LOSI MRC steering geometry?? Help!? - Similar Threads | ||||
Need steering geometry advice. | CHawk68462 | Axial SCX-10 | 38 | 07-24-2013 07:35 AM |
Changing the steering geometry? | Uli | Axial XR10 | 29 | 04-28-2011 04:42 PM |
steering servo problems on MRC | The Wall | Electronics | 2 | 04-29-2010 12:03 PM |
Losi MRC receiver Problems | craddock35 | Losi Mini-Rock Crawler | 17 | 02-21-2010 05:40 PM |
Losi MRC Steering issue | llinneman | Losi Mini-Rock Crawler | 2 | 09-23-2008 09:15 AM |
