07-12-2014, 05:56 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
| Need help diagnosing issue on freshly restored mrc
I just finished rebuilding my old mrc for my son. New chassis, axles, shocks , rx/tx , wheels, tires , shocks. Battery. I got it all together and tried to drive it after binding the new radio system and it would only drive forward and backward. No steering no matter where I plugged in the servo in the rx. Then all of a sudden it would not move at all. I am at my wits end since everything is new. Now I have a good 150-200 into this thing and it's a damn paper weight still. Does anyone have any ideas. When all the servo plugs are unplugged and battery is hooked to the esc it flashes red until you turn on the on switch or plug it into the rx then it stops flashing I'm about to use it for target practice and say screw it and get him a honcho Sent from my iPhone using Tapatalk Last edited by Tom95YJ; 07-12-2014 at 06:00 PM. |
07-12-2014, 06:18 PM | #2 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
| Re: Need help diagnosing issue on freshly restored mrc
Did you go through the binding process with the esc?
07-12-2014, 06:38 PM | #3 |
Yep Sent from my iPhone using Tapatalk |
07-12-2014, 06:45 PM | #4 |
Is the battery ok? All the connections good going from the esc> servo>receiver?
07-12-2014, 06:49 PM | #5 |
All are great and brand new battery was fully charged with a peak charger Sent from my iPhone using Tapatalk |
07-12-2014, 08:02 PM | #6 |
Seems like something went bad with the servo if the esc/rx and battery are ok. Are you using a bec? Does the servo make any noise when powered? Maybe someone else can chime in with other ideas since I cant see the truck.
07-12-2014, 08:08 PM | #7 |
No noise from the servo. I'm not running a bec Sent from my iPhone using Tapatalk |
07-12-2014, 08:27 PM | #8 |
What kind of servo? What radio system? Have you tried plugging the servo into a different rig? Have you tried plugging a different servo into ur mini? |
07-12-2014, 09:28 PM | #9 |
Rock Stacker Join Date: Feb 2008 Location: Lincoln RI
Transmitter batteries?
07-12-2014, 10:46 PM | #10 |
Tx batteries are fresh out of the pack. The servo is the stock losi one it worked before I took apart the mrc, I have not tried plugging the rx into another rig yet same goes for servo. Sent from my iPhone using Tapatalk |
07-14-2014, 08:18 AM | #11 |
Rock Crawler Join Date: Apr 2007 Location: presKit
Id test the individual components on another rig it sounds like the receiver, servo, or bec if you have one might be at fault/bad; things go bad all the time for no reason whatsoever
Need help diagnosing issue on freshly restored mrc - Similar Threads | ||||
help diagnosing esc trouble | arbitris | Electronics | 3 | 12-14-2013 03:02 PM |
Upgrading from the stock SCX10 20t/Diagnosing an issue | CHawk68462 | Electronics | 7 | 07-10-2013 11:00 AM |
Need help diagnosing an issue | aebstract | General Crawlers | 19 | 08-12-2012 03:04 AM |
need some help diagnosing this electrical issue - VIDEO | iamsuperbleeder | Electronics | 15 | 09-17-2011 10:08 AM |
Freshly painted MRC Bods- 72 C10 and Descender | Dale Gribble | Losi Mini-Rock Crawler | 4 | 07-20-2009 07:30 PM |
