02-09-2017, 06:32 AM | #61 |
| Re: Jato's Monster Bolt I ordered Jato rod ends as suggested. And the drag link was on the wrong side of the axle. I was just an idiot when installing it. |
02-09-2017, 07:26 AM | #62 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
I can't tell you how many times I've installed something incorrectly... especially on a crawler.
02-09-2017, 03:25 PM | #63 |
Two questions. 1. The universals have a lot of in and out play. What shims can I get to fix that? 2. Should the rear C-hubs be clocked for maximum caster like the front or should the be set to neutral? |
02-09-2017, 03:38 PM | #64 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
Id set rear for neutral. ofna did/does sell 5x8 shim packs. i put them be hind the hex pin. |
02-09-2017, 03:54 PM | #65 |
Traxxas 1285 shims
02-09-2017, 04:04 PM | #66 |
get metal shims, the teflon, plastic, etc ones shrink, kink, compress and have always caused problems for me.
02-09-2017, 04:33 PM | #67 |
Here's something I've never run into. Robinson spur and pinion. The grub screw for the pinion is in the way and the spur runs into it. It's close enough where the spur will pass it, but not cleanly. I can't move the pinion back any farther and flipping the pinion puts it directly in the way of the spur. Here are the three options I can think of. 1. Put washers between the motor and motor plate. 2. Shorten the grub screw. 3. Make the flat spot on the motor shaft longer so I can push the pinion farther onto the shaft. I'm not fond of this option. Any other suggestions? |
02-09-2017, 05:04 PM | #68 |
Your option 1 or try another brand pinion.
02-09-2017, 05:43 PM | #69 |
Shorten the pinion so it sits on the shaft deeper or file the tip of the grub screw. I've done both without issue. Edit: maybe you should add robinson to your shit companies list with vp. |
02-09-2017, 06:04 PM | #70 |
I was going to run a larger pinion, that looks like either using a different pinion, or a larger pinion would clear that issue up. That pinion looks a bit small for the punishment that it's going to be put through. |
02-09-2017, 07:36 PM | #71 | ||
| Re: Jato's Monster Bolt That's what I chose - washers between the motor and motor plate. I just hope the motor stays put. Quote:
Ha. My first ever issue with Robinson. Definitely not shit list worthy. Quote:
I got the truck together and we have four wheel steering. Now I just have to wait for the snow to try it out. | ||
02-09-2017, 08:16 PM | #72 |
The real fix is to dump that heavy piece of crap slipper/spur setup. I bought one when it was the "in" thing to run and learned to dislike it due to weight. Grab a traxxas slash slipper and slap it on there in place of the Robinson unit and use a lightweight spur that's spaced out from the motor. I've since dumped the Robinson unit in favor of another stock slash unit. This slipper is available without the shaft and all that. It drops right onto a supershafty input shaft. https://www.amazon.com/Traxxas-6878-.../dp/B000FLVMBA |
02-10-2017, 05:16 AM | #73 |
Slippers are for Cinderella.
02-10-2017, 06:06 AM | #74 | |
| Re: Jato's Monster Bolt Quote:
Slipper clutches are overrated. I never eliminate them, but I lock the nut down as tight as it will go. Can I get an amen? | |
02-10-2017, 07:10 AM | #75 |
I agree that slippers are overrated for sure. But the traxxas unit won't slip when cranked down and it let's you run cheap spur gears in a favorable location compared to the other options.
02-10-2017, 07:21 AM | #76 |
RCC Addict Join Date: Aug 2008 Location: Paulina
So the traxxas slipper unit won't fit on the stock axial input shaft?
02-10-2017, 07:33 AM | #77 | |
It fits the old top shaft meant for the single disk slipper clutch if you drill out the drive pin hole from 1.5mm to 2mm. | |
02-10-2017, 07:58 AM | #78 |
| Re: Jato's Monster Bolt I have one I filed to fit the stock slipper shaft. The pin slot is too deep in the traxxas unit so when you install the slipper it locks up against the motor plate unless clearanced. On a supershafty input not only is the pin 2mm but it's a few mm further out on the shaft.
02-10-2017, 08:11 AM | #79 | |
I used the Jato slipper assembly on one of my trucks and it clears the motor plate with the Axial top shaft. Maybe that rear slipper plate offset is a little different between the trucks. | |
02-10-2017, 08:51 AM | #80 |
| Re: Jato's Monster Bolt Maybe? Both slippers look the same but the supershafty top shaft is made to run that silly robinson slipper so it's builtdifferent than the stock shaft.
Jato's Monster Bolt - Similar Threads | ||||
Jato's SMT10 | JatoTheRipper | Mega/Monster Trucks | 241 | 12-28-2018 09:35 AM |
Monster Bolt Build | kmnss | Mega/Monster Trucks | 6 | 02-08-2017 12:40 PM |
