Go Back   RCCrawler Forums > Miscellaneous > Mega/Monster Trucks
Thread: Scratch build truck ideas?
Old 06-01-2019, 02:42 PM   #1
Default Scratch build truck ideas?
Since the SMT10 is out for now the only contenders in the 1/10 2S category are the new CEN that isn't out and the MST MTX-1 and both of which use narrow axles and seem to be more 1/12 like than 1/10. I want about a 13" WB and brushless. Can I use one of my scale trucks and just put 1" hex wideners on each side? I do like the ladder chassis look better for an MT.
kennebell50 is offline   Reply With Quote
Old 06-01-2019, 03:46 PM   #2
indybama's Avatar
Default Re: Scratch build truck ideas?
Check out a few of the threads in this section. I built mine from ground up
Sent from my SM-J327VPP using Tapatalk
indybama is offline   Reply With Quote
Old 06-02-2019, 09:30 AM   #3
It works pretty well with the TRX-4.
TRX-4 Monster Truck?
TooOldForThis is offline   Reply With Quote
Old 06-02-2019, 11:24 AM   #4
You think the stock axles would be ok with 1" extenders on each side?
Old 06-02-2019, 02:41 PM   #5
I think with heavy tires and brushless it would be pretty easy to break things with 1" on each side. IMO it would probably look kinda funny too.
Old 06-02-2019, 05:06 PM   #6
Ya, I figured that too. Too bad there arent any decent 12mm hex axles that are kind of wide.
Old 06-02-2019, 05:35 PM   #7
indybama's Avatar
There are. Ive got 2 sets of 12mmx28mm hexes. They make my m/t wide enuf to not rub, but my wheel are so thick they stripped one out. Got a different style n the nut piece wasnt long enuf. So im runnin 12mmx14mm extensions n the only rubbin i have is on the lower links at full throw
https://rover.ebay.com/rover/0/0/0?m...2F192899358415
https://rover.ebay.com/rover/0/0/0?m...2F332376124380
Pic is the 12mm x 14mm
Old 06-02-2019, 06:09 PM   #8
I mean entire axles. Kind of like the AR60s but from someone else since those werent that great and are pulling high money because there is no other wide ones.
Old 06-02-2019, 11:47 PM   #9
Maybe? Axles
oops, I meant to link this page, specifically to show their axle tube spacer setup: http://www.freestyle-rc.com/axles.html
I'm not having luck finding their hex-to-hex width though, maybe someone else can chime in.
TheLetterJ is offline   Reply With Quote
Old 09-21-2019, 03:36 PM   #10
Well, I am still wanting to build a truck and all the AR60s for sale are locked diffs. This has been quite a challenge. I wish Axial would just release a new variant of the damn thing.
Old 09-22-2019, 08:07 PM   #11
You can get the locked Ar60's take out the locker and just drop diffs gears in. But you definitely need beef tubes or equivalent though.
Sent from my SM-G965U using Tapatalk
FormallySkullking is offline   Reply With Quote
Scratch build truck ideas? - Similar Threads
RCO's scratch build Trophy Truck RCO 2.2 Scale Rigs 10 02-23-2016 09:58 PM
scratch build rc trail truck pattyv12 2.2 Scale Rigs 16 11-13-2014 04:06 PM
SCX10 Mud Truck, Mega Truck Ideas thejudge1 Mega/Monster Trucks 7 11-08-2014 07:33 PM
Boolean21's 1/10 M923 - 5 ton truck - Newbie' try on a scratch build body... :D boolean21 Multi Axle Rigs 46 08-31-2012 03:54 AM
Starting with a new truck or building from scratch? BackToThePast Redcat Crawlers 6 01-11-2012 06:13 PM
