06-15-2020, 12:47 PM | #1 |
Rock Stacker Join Date: Nov 2019 Location: uk
| Internal bec enough power?
The HW max10 SCT esc I am using as a 4amp bec,is this enough for a 25/35kg servo?
06-15-2020, 01:41 PM | #2 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Internal bec enough power?
What wheels (rims&tires) are you running? 4 Amps will probably be enough to get it going so you can decide if you want more after some drive time. Odds are it'll be ok but that'll depend on exactly what servo and wheels you run. |
06-16-2020, 09:36 AM | #3 |
Jconcepts tribute wheels and tyres. bigger than the stock kit ones.
06-16-2020, 11:05 AM | #4 |
Depends how much low speed maneuvering you think you'll be doing I guess. Lots of low speed stuff, you'll want an external BEC. Otherwise I'd guess it'll be fine. Really depends on the servo and it's power consumption needs. |
06-16-2020, 12:00 PM | #5 |
Get an external bec.
06-17-2020, 10:15 AM | #6 |
| Re: Internal bec enough power? |
06-20-2020, 09:06 AM | #7 |
I have a CC 10amp BEC the heat shrink kind,not very big BUT to big to fit into the RX box with a small 3 ch rx!
06-21-2020, 12:38 AM | #8 |
Have a read down memory lane: Yes you need an external bec |
06-22-2020, 01:29 PM | #9 |
06-26-2020, 03:51 AM | #10 |
06-26-2020, 04:13 AM | #11 | |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Internal bec enough power? Quote:
For a 25kg servo you dont need that ...not even running it on 7,4V Last edited by themountain; 06-27-2020 at 03:24 PM. | |
06-26-2020, 08:11 AM | #12 |
Newbie Join Date: Dec 2019 Location: US
Tribute wheels and tires you need a bec and servo cranked up a little to turn them babies with ease and speed. Especially if your crawling those wheels and tires hang up easy cuz of the size but let you tackle nearly any terrain Also if your crawling with those rims and tire you may wanna go brushless crawler motor Sent from my SM-N910T using Tapatalk |
06-28-2020, 04:32 AM | #13 |
Its got a 3200kv BL and will never see any crawling. its got a HW max10 sct esc with a 5 amp bec ,read a couple of post about HW esc bec being underated and should be ok.
Internal bec enough power? - Similar Threads | ||||
Internal bec ? | callaway | Vaterra Ascender | 12 | 04-28-2018 09:58 AM |
internal esc bec or external bec | 3sgte | Electronics | 15 | 01-15-2015 08:23 PM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Tekin FX-R internal BEC ... | Locked Up | Electronics | 4 | 11-02-2008 09:24 PM |
High Power BEC/Servo Power Supply | MANTIS | Electronics | 14 | 08-09-2006 03:33 PM |
