08-23-2019, 09:52 PM | #1 |
Newbie Join Date: Dec 2015 Location: Granite City
| Dim Stock SCX24 LEDs
This is only for people with LED OBSESSION COMPULSION DISORDER, with their RC stuff and their LEDs go dim. On the stock Axial ESC/RECEIVER next to the STR channel that the servo plugs into is slot CH2, there is a big difference in what pins you plug in the LEDs. Stock LEDs only has a 2 pin plug. If you plug negative side plug on the top pin you get DIM FRONT LEDs. If you plug Negative side plug in the Bottom and Positive side plug In the Middle Pin, YOU GET BRIGHT LEDS. It’s also the same in other slots ( AUX, LED, LED,)
08-29-2019, 09:36 PM | #2 | |
| Re: Dim Stock SCX24 LEDs Quote:
Sounds like the dim plugging way is reverse voltage to the LEDs, they don't like reverse voltage, but if it's enough voltage you still get light. Ensure they are plugged in proper orientation. | |
08-30-2019, 04:52 AM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
You can also get working brake lights if you plug the rear lights into the proper slot in the proper orientation Sent from my Pixel 3 XL using Tapatalk |
Dim Stock SCX24 LEDs - Similar Threads | ||||
Axial SCX24 Parts - BACK IN STOCK! | RPP Hobby | RPP Hobby | 0 | 08-22-2019 04:16 PM |
IN-STOCK NOW the Axial Racing SCX24 Deadbolt 1/24 Scale 4WD RTR! | RPP Hobby | RPP Hobby | 1 | 05-29-2019 04:16 PM |
Remote Switch for LEDs with Dim function | heyok | Vendors Electronics | 4 | 06-27-2016 02:36 PM |
Tekin fxr ALL LEDs are dim NEED HELP!!!! | BUGGYBOY | Electronics | 34 | 06-08-2013 05:23 PM |
Remote Switch for LEDs with Dim function | heyok | Electronics | 3 | 05-02-2013 12:13 AM |
