04-04-2021, 04:27 PM | #21 | |
Pebble Pounder Join Date: Dec 2017 Location: Pinehurst
| Re: Furitek Tegu Esc Quote:
Now I am running the lizard and the firmware wasn't messed with to satisfy customer demand for 3s, but I am sure they will get the Tegu refined. But until then I will stick with lizards for my rigs Sent from my SM-G970U using Tapatalk | |
06-27-2021, 06:58 PM | #22 |
Rock Stacker Join Date: Aug 2020 Location: Philadelphia
mine just keeps going for 2 seconds after I let go of trigger
07-01-2021, 09:13 PM | #23 | |
Quarry Creeper Join Date: Jul 2020 Location: US
Also, i believe firmware is now up to like 1.8 or better?? Just FYI. I had tried 3s after flashing 1.5, 1.6, and 1.7FW, and had the short-run & cut-off motor issue....tbh, i have no idea what i did to finally get the truck moving again, but, i did get rolling on 3s for a day or two, and have since been running 2s, simply because my only "mini" 3s pack, is rather heavy despite its small stature!, Was messing up my CoG-zen! Lol. ....but- always calibrate throttle trigger when switching ANY one/or mixture of: Punch Startup power Change from 2s-3s Modify throttle curve Drag brake/brake settings Etc, etc... Also, BE SURE to set app settings to "brushed", or, "brushless", as well as CRAWLER, as mine defaults to drifting car/brushed?? Whenever first install, and a time or two it did same thing after FW update! In fact, THAT might have been my 3s dilemma!? Also i found that (at least MY TEGU needs you to HOLD THROTTLE position(s) UNTIL the app says the next step/throttle position to calibrate!!!! So i always, yes-calibrate, set neutral (FS GT5) save, when prompted, full throttle, HOLD while pressing 'save', and UNTIL app tells to do full reverse, then HOLD FULL REVERSE, WHILE SAVING, UNTIL the app says "calib. Successful". Then system reboots itself, gives arming beeps, and you're golden! Read-Up! Mod-On! Crawl EXCESSIVELY! | |
07-05-2021, 09:47 PM | #24 | |
10-03-2021, 09:29 AM | #25 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
I just got my Tegu wired in yesterday. First power up, everything worked as advertised. Bluetooth connected, few updated to what ever latest version, etc. I power cycled, checked basic settings and crawled around my work bench for a few mins. Motor quit, I assumed I had hit LVC so I swapped batteries. Powered back on but ZERO response from the esc. I am getting power to the rx and servo. No leds on the tegu and no motor response, Bluetooth does not connect either. Any suggestions? Fs-gt5 Fs6 rx Stock servo Tegu Komodo 1400kv Stock 2s 350 Lou |
10-08-2021, 01:48 PM | #26 | |
I have been messaging and troubleshooting with Tony Furitek on FB. I have the identical issue as you. At this point, I think they are sending me a new ESC. It really is such an odd issue... The Tegu itself is completely unresponsive, no LED's, no bluetooth discoverable on any device I have tried. Yet, RX and servo still have power. Lou | |
Furitek Tegu Esc - Similar Threads | ||||
Furitek Lizard esc + 8000kv = one sick scx24 | Unclelee | Micro Scale Rigs | 18 | 02-04-2022 12:05 PM |
Scx24 C10 Furitek and Surpass brushless outrunner | Unclelee | Micro Scale Rigs | 10 | 01-26-2022 02:35 AM |
Furitek Tegu 3S issues... | Rcing4life | Scale Videos! | 0 | 03-26-2021 09:20 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
