03-31-2014, 08:51 PM | #301 |
Pebble Pounder Join Date: Mar 2013 Location: labrador
I wish I had a workshop like you two. Lol. The Trukkracea |
03-31-2014, 08:58 PM | #302 |
| Re: Szczerba's Tow Rig Shucks.. Just wait till trailer fab starts. The in 1:1 the rig is 1/3 the total length of the rig/trailer setup. I don't think I will make this scale version trailer 66% longer than the truck. That would be like a 60" trailer. Probably going for a 30" length trailer. Wishes can come true! |
03-31-2014, 08:59 PM | #303 |
60"? You're gonna need another bench!
03-31-2014, 09:07 PM | #304 |
| Szczerba's Tow Rig Ill make one, if needed. Getting good with the welder finally. Good is a relative term when speaking of my MIG welding. Example. My proportions were a bit off. May be a 60/40 setup. Ill "eyeball" the trailer length when i get there. Trying to figure out how to make these angled trailer skids too. I am not setup to cut a 15 deg angle on 1/2", 8.5" square piece of metal tube. I have an idea or two. Last edited by Szczerba; 03-31-2014 at 09:10 PM. |
04-01-2014, 08:09 PM | #305 |
| Szczerba's Tow Rig
Hastily tacked on trailer skids. Possible big boy winch setup. Tube tapered down to fit some bearings. Some old spur holder with mod1 gear. I will need to make a new steel spur plate. Cant really place the motor directly in front of mount as winch line will probably get in the way. Last edited by Szczerba; 04-01-2014 at 08:12 PM. |
04-02-2014, 09:13 AM | #306 |
Rock Stacker Join Date: Mar 2012 Location: North Highlands, CA
That ought to pull some ish lol. Nice.
04-02-2014, 09:15 AM | #307 |
| Re: Szczerba's Tow Rig |
04-02-2014, 10:24 AM | #308 |
04-05-2014, 01:03 PM | #309 |
Trans mounting |
04-05-2014, 02:38 PM | #310 |
The trans mount looks nice and study, great placement to keep the driveshaft angles sane. |
04-05-2014, 02:57 PM | #311 |
04-06-2014, 10:52 AM | #312 |
Just messing around in the shop. |
04-06-2014, 11:26 AM | #313 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
are you really going to have a single motor to move this beast?
04-06-2014, 11:32 AM | #314 |
04-06-2014, 12:10 PM | #315 |
why not use a transmission from a summit and have a dual. 775 motor set up. you'll have plenty of power. hell, you could ge away with just a single 775 motor
04-06-2014, 12:22 PM | #316 | |
| Szczerba's Tow Rig Quote:
The brushed 540 is for mockup only. I ran the Holmes sensored outrunner in my 15lbs CXT geared 10:1 at the spur/pinion. Worked great. 8x8 is sitting at 10.8:1 now. http://holmeshobbies.com/Holmes-Revo...Outrunner.html Szczerba's 2.2 CXT Holmes also makes a 550 sensored outrunner. http://holmeshobbies.com/Revolver-S-...Outrunner.html | |
04-06-2014, 05:31 PM | #317 |
Something about a winch. |
04-06-2014, 05:34 PM | #318 |
Bitchin'. Is there enough reduction there to give it good pulling power?
04-06-2014, 05:38 PM | #319 |
04-06-2014, 06:43 PM | #320 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
Yeah you may wanna try to use the gru. If not you may very well have the first scale ski rope winch.. That 100 turn motor and the gru it should pull a 1:1 |
Szczerba's Tow Rig - Similar Threads | ||||
f350 tow truck/ tow rig | bbnate804 | 1.9 Scale Rigs | 13 | 11-19-2012 07:15 PM |
Big Rig tow rig | codycodeman16 | General Crawlers | 1 | 02-05-2010 09:43 PM |
Tow rig # 2 | braceysdad | 1.9 Scale Rigs | 58 | 06-27-2007 01:08 PM |
Tow rig #1 | braceysdad | 1.9 Scale Rigs | 46 | 06-11-2007 11:06 AM |
New Tow Rig | Will | Chit Chat | 10 | 07-22-2005 12:02 PM |
