11-02-2013, 06:52 PM | #41 |
Rock Crawler Join Date: Mar 2009 Location: Alvin,Texas
| Re: need help to get on right path
There's a whole lot of t cases out there besides rc4wd . You can make anything fit into anything and work with anything with a little work .
11-02-2013, 07:15 PM | #42 |
Rock Stacker Join Date: Jan 2011 Location: santafe
pump the brakes.....what do yall know about jun fac can't find an english website but they got a sweet setup with that sawback nvm my bad spoke to soon found website helps if you spell it right but what are the interference issues on axle says planetary tcase only don't know why that would matter that's what I been stressed out about thing like that make no sense Last edited by THX_138; 11-02-2013 at 08:03 PM. |
11-02-2013, 07:19 PM | #43 | |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: need help to get on right path Quote:
--Dan Last edited by sickcivic95; 11-02-2013 at 07:22 PM. | |
11-02-2013, 07:45 PM | #44 |
Most of my stuff comes from lowes or Home Depot . If they don't have what you need local . I order from metalsdepot.com or mcmastercarr .
11-02-2013, 07:49 PM | #45 |
I can't post the link but it explicitly says only use with such and suck transfer and transmissions but ill just run what I find on ebay that's water tight and low gearing ill cut chop and rebuild wen I fing an issue hell bounder were would I find small metal material to make cross member for tcase if needed don't know were flat bar that size would be not any hobby shop I've ever seen yea I know that site cool ill write that down also earlier b.a.s behind axle steering conversion Last edited by THX_138; 11-02-2013 at 08:02 PM. |
11-02-2013, 07:49 PM | #46 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: need help to get on right path |
11-02-2013, 07:59 PM | #47 | |
| Re: need help to get on right path Quote: Ill second online metals, its a division of Thyssen Krupp who is a world wide metal seller with great quality metal. I buy from them all the time for personal and business use. They may not have some of the smaller dimensioned items we use but for steel, delrin,aluminum, etc they rock. They can cut stock down to pretty much any size you need Also what axle are you talking about? All of their axles show recommendations but not MUST use Unless it specifically notes it. These are excerpts from their pages and don't apply to all models I'm just using for examples. These are all recommendations for them to push more of their own product, other than the last one and that's explainable. Transmission: This axle is designed to work with our R2 Transmission, Planetary Reduction Tranny, or Transfer Case This axle is designed to work with R2 black transmission (Z-U0009), R2 Silver (Z-U0010), R2 2 Speed (Z-U0011) or AX10 transmission. You do have to purchase a special Punisher Shaft II with 5mm holes. This is because of a different output shaft size as I mentioned earlier. Also most guys refer to the steering mod as B.T.A. -- Behind The Axle, hence my confusion. --Dan Last edited by sickcivic95; 11-05-2013 at 12:49 AM. | |
11-02-2013, 08:51 PM | #48 | |
Pebble Pounder Join Date: Jul 2011 Location: On the trails
Not trying to steal from this thread, how do you like that torch? I'm currently using a mapp/oxygen disposable torch and costs about as much to run as my 3/4 ton truck.. I've been thinking of picking one of those up from my supply house but didn't know how small (fine) you could get the flame down too. I'm a plumber and we have b tanks at the shop but they haven't been used in Years. I use a smaller torch that runs off just mapp which allowse to sweat up to 2" copper but will not get hot enough for brazing. | |
11-02-2013, 09:09 PM | #49 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
I love the Turbo Torch! Not sure the part number, but I use the smallest tip available for the torch. I can braze a joint literally twice as fast with a turbo torch as I can with MAPP. I keep a candle lit on my workbench for quick lighting. Also learned to keep the flux coated rod in the flame to pre-heat while heating up the metal. Once red hot, the pre-heated rod flows within seconds. |
11-03-2013, 07:38 PM | #50 |
any one have off the cuff links to some body dealers....I can't use search with my phone and its been rough going the 80 some odd pages of threads let me rephrase that HARDBODY trying to get away from the common bodies Last edited by THX_138; 11-05-2013 at 01:43 AM. |
11-04-2013, 09:38 AM | #51 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
If you want a hard body that isn't the Tamiya or RC4WD offerings, you are going to be looking at toy grade RCs. In that case you'll buy the whole toy RC, take the body off it and set the rest aside. The only way to find those same bodies sold as just the body is to go on EBAY or the classifieds here. Try Amazon and flip through the toys. I will say, even then most of the bodies are Jeeps or Ford pickups. Otherwise, buy a bunch of styrene and start learning to scratch build, then you can make anything you want. One nice thing with styrene is it is cheap, so you aren't out hundreds of dollars if it goes wrong. |
11-05-2013, 12:13 AM | #52 |
MODERATOR Join Date: Oct 2010 Location: RC Land
I highly suggest you find a computer and spend some time with the search function and a keyboard. Lets do this. Post some pictures of your current RC and ask a specific question to match what you post for the picture. Your comments and questions are so scattered and mixed its confusing at best. Sounds like you need some actual hands on time with your build and then come back with a specific question as each situation arises. |
need help to get on right path - Similar Threads | ||||
New Wraith, am I on the Right Path? | REV666 | Axial Wraith | 33 | 03-05-2013 03:12 AM |
what is the better path? | jkabee | Axial SCX-10 | 5 | 01-08-2013 10:23 AM |
World's Scariest Path | Skeeno | Chit Chat | 7 | 12-22-2009 12:53 PM |
Am I going down the right path? | neuro242 | Axial AX-10 Scorpion | 13 | 10-07-2009 08:27 PM |
