Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Which type motor runs smoothest and strongest at crawl speeds
Old 07-04-2015, 11:11 AM   #1
Default Which type motor runs smoothest and strongest at crawl speeds
For crawling, which type motor works best, all other things being equal, a sensored, brushless motor or a brushed motor? The stock Axial come with brushed and runs pretty smooth and quiet, from what I've seen. Isn't that a cheaper setup than brushless-sensored?
gfmucci is offline   Reply With Quote
Old 07-04-2015, 01:05 PM   #2
Default Re: Which type motor runs smoothest and strongest at crawl speeds
Brushed, 35t is popular
BlownChevelle is offline   Reply With Quote
Old 07-04-2015, 01:23 PM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
The higher cost ones run smoother than lower cost ones. In general, brushed will give better control at low cost. The upper end is a handwound five slot like my CrawlMaster Pro or Puller 500 Crawl. With brushless, it takes a special design to come close to what brushed offers.
JohnRobHolmes is offline   Reply With Quote
Old 07-05-2015, 05:47 PM   #4
So, instead of spending $200 on a sensored, brushless, 4-pole motor/esc combo, spending $100 on a sensorless, brushed 2-pole motor /esc combo will be smoother at crawl speeds?
Old 07-05-2015, 06:18 PM   #5
Its all very well to want the smoothest motor..but will you be able to drive slow and smoothly?
I have x2 hh 35T torque master pro's, and being new to the hobby i found them to be fantastic. Good low down torque and with a 3S lipo you had plenty of punch. But 13T i've heard are great also, so get your wallet ready for some craziness.
It all comes down to personal preference i suppose and how crazy your crawling is going to get.
Bully2RockRomper is offline   Reply With Quote
Which type motor runs smoothest and strongest at crawl speeds - Similar Threads
Out of sync motor speeds? sixOHfour Axial XR10 5 11-05-2012 10:49 PM
Motor speeds J8crawlerdude Axial XR10 4 12-18-2011 08:22 AM
Motor glitchy at low speeds RksPlz Electronics 10 05-12-2011 03:25 PM
Motor speeds? robert97dodge Electronics 13 12-26-2008 08:34 PM
Poll: What is the strongest type of metal revoster Tools, and Procedures 10 06-02-2006 11:00 PM
