02-02-2017, 04:20 AM | #1 |
Rock Stacker Join Date: Jan 2017 Location: Australia
| motor mounting issue
i have a new 55t form axial and the 2 mount points seem to be an odd size bolt. i have found a grub screw that is unf 44 that is a perfect fit but this dosnt seem right? i can not get bolts this size.
02-02-2017, 06:12 AM | #2 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: motor mounting issue
It should just be a m3X6mm. http://www.ebay.com/itm/Axial-Cap-He...-/311416962450 |
02-02-2017, 06:25 AM | #3 |
yes thats what i thought but like i said the dont fit in and a unf dose?
02-02-2017, 10:28 AM | #4 | ||
| Re: motor mounting issue Quote:
Tech Stuff - Mechanical - Threads Edit, maybe put a little grease on the screw threads and carefully screw them into the motor. Pic of motor with screw holes and the two screws side by side? | ||
02-02-2017, 01:05 PM | #5 |
yea i was kind of expecting that sort of response but been this is my first motor i wanted to be sure. i am a boilermaker buy trade and dealing with treads is parts of the daily grind so i might run a m3 tap through it and clean it out assuming it got to many coats of paint in the thread. thanks for the help guys. |
02-02-2017, 02:25 PM | #6 |
it tapped out easily with no issues. i mad sure to use a number 3 tap without the starting tip on it so it bottom out in side without doing damage. m3 bolt fits perfect now.
02-02-2017, 05:23 PM | #7 |
Glad to hear it worked out for you. Another thing I've done is take a new socket head capscrew, grind a groove in the tip and up the side of the starting threads (kinda like a tap, some self-tapping screws come like this) then thread it into the holes with a drop of oil on it, cheap, easy and already a "bottoming tap". |
02-02-2017, 06:07 PM | #8 |
Newbie Join Date: Aug 2016 Location: Townsville
Sometimes, even a slight chamfer (to make it closer to being conical) can be enough. More so if the bolt is the problem, rather than the thread in the port. Sent from my iPad using Tapatalk |
02-03-2017, 03:43 PM | #9 |
Newbie Join Date: Jan 2017 Location: Hubbard
Like posted above, sometimes I'll use a file to make a small groove at a 45* angle on the tip of the screws. It helps chew through any burrs or excess paint that may be in the threads.
motor mounting issue - Similar Threads | ||||
Axial yeti tire mounting issue | -SCXD90- | Axial Yeti | 17 | 03-01-2016 07:13 PM |
AX10 Motor Plate/Motor Mounting Problems | md7989 | Electronics | 8 | 11-25-2010 01:30 PM |
Motor mounting on the SCX10 | luv2ridemx | Axial SCX-10 | 1 | 02-17-2010 11:38 PM |
Mounting the battery over the motor on a CC-01 | SoCalMike | Tamiya XC/CC01 | 8 | 07-09-2009 05:56 PM |
Alternate motor mounting | Merrixs | Tamiya Clod Buster | 3 | 03-01-2006 05:09 PM |
