Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Underdrive gear help..
Old 06-01-2017, 02:37 PM   #1
Default Underdrive gear help..
I have built a set of ar60s for my maverick scout, installed 43/13 underdrive gear in the rear axle but I am unsure if I should use the gasket(?) that the stock gear has beetwen the gear and diff. Help a newbie pleaseee...
Vagos2 is offline   Reply With Quote
Old 06-01-2017, 03:54 PM   #2
Default Re: Underdrive gear help..
If you are using the stock locker then yes you need the gasket, aftermarket locker, no
allanon1965 is offline   Reply With Quote
Old 06-01-2017, 11:11 PM   #3
Thanks for the reply! I have assembled it without the gasket.. fixed it already and it's "crawl after work" for me today!
Underdrive gear help.. - Similar Threads
Differential gear mesh (underdrive) summerof95 Axial SCX-10 10 01-05-2015 09:19 PM
Underdrive gear problem VTHokie Axial AX10 2nd-gen 15 05-08-2014 11:46 PM
underdrive gear noise? Gravebane525 Axial SCX-10 6 09-22-2013 12:47 PM
HTML code is Off
