06-09-2017, 12:49 PM | #21 | |
Newbie Join Date: Jun 2017 Location: Arcadia
| Re: New Crawler/ Rock Racer for under $200 Quote:
I guess I was just misled by the title that he might want a rock racer or a crawler not both in one which I imagine is tough in that price range. | |
06-09-2017, 02:09 PM | #22 | |
06-09-2017, 03:35 PM | #23 |
Rock Stacker Join Date: May 2017 Location: Austin
Guys, what about an Axial Yeti Jr? it is a bit small but it looks good for the price $160, it can do some crawling and it is fast for a crawler, it will surely beat all of the toy RC cars i have had. Is it easy to change the wheel transmitter for a twin stick one on that car? how good is it at crawling and what is its top speed? how easy it is to upgrade? Also, what is the feiyue website? Last edited by latinomanz; 06-09-2017 at 04:08 PM. |
06-10-2017, 06:36 AM | #24 |
Quarry Creeper Join Date: Dec 2016 Location: FL
Honestly, for what your looking for I would find a Wraith, or Bomber RTR. Trying to go cheap is only going to be an annoyance in the long run. Also a Yeti Jr. is not a crawler nor does it do crawling it is a Short Course Truck which is meant to go fast and have a very low center of gravity so it would bottom out on everything, let alone it has no slow speed.
06-10-2017, 10:33 AM | #25 | |
06-10-2017, 11:33 AM | #26 |
Yes. A cheap sealed can motor with a lower turn would make a bigger difference in speed though. My son's has a 27t with 17/80 (might be 17/84, don't remember) gearing on 2s and it's plenty fast while still being capable of some light crawling. With the same setup on 3s, it would wheelie and go jogging speed, but it also stripped the top gear in the tranny in less than one 3s pack.
06-10-2017, 11:34 AM | #27 |
Quarry Creeper Join Date: Dec 2012 Location: Pioneer, 95666
i'm pretty sure the everest 10 is a 2s only system, so the ESC will burn up if you put a 3s battery in it. also, I would suggest looking in the yeti form for reviews of the yeti jr. roughly 80% of what I've read on it is people replacing all the electronics because they last less than a few packs without burning up. the yeti jr. also has open diffs front and rear. |
06-10-2017, 12:09 PM | #28 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
The Everest 10 is 3S capable out of the box. I run a 3S lipo on my son's Everest 10 with stock gearing and motor. It is faster than stock, but still fairly slow (which is good for him as he is 4 y.o.). On my Everest 10, I changed to a 35T RC4WD motor with 3S. It also has an overdrive gear in the front axle and taller than stock tires. I did go down from a 14T to a 10T pinion. It is faster than walking speed, but slower than jogging speed. It is also very torquey. I don't plan to gear up any further as it already can run into heat issues with this setup. When this motor goes I may go down to a 45T motor to avoid heat issues. I do have a fair amount of extra weight in my setup compared to stock...without this it might not have as much of an issue with heat. |
06-10-2017, 01:50 PM | #29 | |
06-10-2017, 04:58 PM | #30 |
| Re: New Crawler/ Rock Racer for under $200 I'd guess around 4 mph. Could also increase the pinion size to 16 or 17 T to gain a bit more speed if desired.
06-10-2017, 05:57 PM | #31 |
I see, still faster than my 2mph toy car. Can the Yeti Jr go up an average US sidewalk without bottoming out? |
06-10-2017, 06:00 PM | #32 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
Whomever suggeted the Yeti Jr. to you should be... I'm not going to say it...
06-10-2017, 06:15 PM | #33 | |
here's the product page for the yeti jr. it's tiny compared to a 1/10 scale crawler, with 3" tall tires, and an 8" wheelbase and a 5-1/2" wide axle. Axial Racing - Yeti Jr. | |
06-10-2017, 08:00 PM | #34 |
It was either mentioned here, or in your other thread, but the RGT Rock Hammer looks like the drivetrain is identical to the Redcat Everest 10, but it has a full length TVP chassis, better suspension (lower links are mounted at the skid, instead of outside the frame like the E10) hinged rollcage, bumpers, wheel spacers (better stability when going faster or side-hilling), and better/taller tires right at the $200 mark. I think the E10 is a great value as long as you're not trying to build a super scale accurate rig or comp vehicle, but the Rock Hammer looks to be basically an E10 with a few worthwhile extras for not much more money. I think it will be between the Rock Hammer and a Redcat Gen 7 when my 3 year old is ready. & RGT 1/10 Scale RR-4 4wd Off Road Electric Racing Rc Car Rock Crawler Climbing | eBay That being said, I've seen 3 Axial Wraith's and 2 Vaterra Twin Hammers' on my local Craigslist this year all priced at $200. If you don't know what you're looking at, buying used can be risky, but it could also be the best/cheapest way to a decent car. |
06-10-2017, 09:18 PM | #35 | |
Is the twin hammers a good crawler? Does it bottom out easily? It looks like I can get a good deal on one. Is this one good? https://www.amazon.com/gp/aw/d/B072M...5&keywords=rgt Last edited by THX_138; 06-20-2017 at 08:32 AM. | |
06-10-2017, 10:32 PM | #36 |
| Re: New Crawler/ Rock Racer for under $200 If it really is the same drivetrain as the E10 (pretty safe bet) it should travel at roughly half the speed of smell. All the previously mentioned mods would be applicable though. I think if you want a 1/10 that is much faster than about 15mph on a $200 budget, you might be better served just going with a Traxxas Slash (just over $200 for a new one, usually about $120-$150 for a used brushed version, or $250 for a used 4x4 brushless.) |
06-10-2017, 10:39 PM | #37 | |
06-10-2017, 11:21 PM | #38 |
That's exactly the same car that I linked a few posts ago... only my link was cheaper. A few more one liner's and you'll be at 30 huh?
06-10-2017, 11:30 PM | #39 | ||
Well with Amazon I can just return it if I dont like it. Is it faster than the Everest-10? What is a one liner? What do you mean? Quote:
06-11-2017, 04:13 PM | #40 |
The best option that's been brought up so far is when you asked about getting a twin hammers. They're a great vehicle for what you're looking for. I don't know of anything that fits all of the requirements you've listed at the price you want. The twin hammers fits those requirements, but it's$250 for the kit.
Tags |
cralwer, rock racer |
New Crawler/ Rock Racer for under $200 - Similar Threads | ||||
Rock Racer or Crawler | aceisback | Vaterra Twin Hammers | 13 | 03-21-2013 09:18 AM |
Rock Racer vs Crawler | klamp | Newbie General | 7 | 06-22-2011 12:37 PM |
Rock Racer to Rock Crawler Conversion | Orgnoi1 | Axial AX-10 Scorpion | 9 | 03-06-2010 10:07 PM |
hobby grade rock crawler for under $200 | crawlerb | Newbie General | 6 | 06-07-2007 09:26 AM |
