09-21-2019, 06:40 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: albany
| Is there a Paint that mimics bedliner ?
I’m looking for something that gives the texture appearance of line x or rhino liner etc . Anyone ever use anything like this on top of a lexan shell and if so any tips on application ?
09-21-2019, 06:41 PM | #2 |
Newbie Join Date: Jul 2017 Location: Fairmont
| Re: Is there a Paint that mimics bedliner ?
I use rustoleum bedliner spray, painted a full axial cherokee outside the body and it holds very well Sent from my iPhone using Tapatalk |
09-21-2019, 06:56 PM | #3 |
Excellent ty . Is it textured ? Can you post a pic ?
09-21-2019, 07:21 PM | #4 |
Its actually bedliner Sent from my iPhone using Tapatalk |
09-21-2019, 08:02 PM | #5 |
| Re: Is there a Paint that mimics bedliner ? |
09-22-2019, 12:27 AM | #6 |
| Re: Is there a Paint that mimics bedliner ? Yep. I've used the same stuff as bedliner on a handful of lexan bodies and even started using it as my final backer coat (inside the body) to toughen up the body a bit... don't know if it really helps structurally, but it has at least kept tire rub from taking off the paint.
09-22-2019, 06:57 AM | #7 |
Yeppers Rustoleum bed liner. Adheres well to lexan, finish is close to looking scale. Hang up and Drive |
09-22-2019, 10:50 AM | #8 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
The top of my 4runner is rustoleum bed liner has some good texture I’ve used it on everything. Seems to stick well to lexan as well. Sent from my iPhone using Tapatalk |
09-22-2019, 02:32 PM | #9 |
I’ve also used the Rustoleum bed liner on parts of my rigs. Make sure you prep what you’re going to spray really well. With lexan, scuff the area up with some scotch brite pad or some steel wool. Then wipe down with isopropyl alcohol. Ready to spray.
09-22-2019, 08:54 PM | #10 |
I've used Rustoleum "stone finish" in the past, it gives a believable texture that passes for bed liner. Last edited by BigSki; 09-22-2019 at 08:56 PM. |
09-25-2019, 07:16 AM | #11 |
Pebble Pounder Join Date: Nov 2009 Location: Newmanstown, PA
I too have used the Rustoleum bed liner spray on all of my bodies with great success. Some of them are at least ten years old, and it has never chipped or flaked off. Usually I've scuffed the area I'm applying it to really well, but on my most recent body I just cut the overspray film around the bed area, and gave it a quick light coat of Tamiya black, and then applied the rustoleum bed liner. So far it is holding up just fine. I'll add that distance is your friend when spraying the Rustoleum, it comes out fast and thick as it is meant to cover large areas of a pickup bed. So if you're not careful it can build up way to thick and run on the small area you'll be painting on a lexan shell. |
09-25-2019, 08:20 AM | #12 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
i sprayed some on my sliders for the 79 ford. HAD pics but tinypic went kaput and i lost the entire thread. but yes, rustoleum bed liner thirded. |
09-27-2019, 09:22 AM | #13 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I use duplicolor truck bedliner paint, and I've found it to work extremely well. It holds up very well, and looks perfect. I've used it in the bed of my basher bodies with no base coat and it doesn't chip off. On my Gen8, I laid down a couple coats of black Duratrax body paint for adhesion, then sprayed the Duplicolor over that. That truck has taken some tumbles and the paint still looks 100% perfect. Last edited by Jim85IROC; 09-27-2019 at 09:28 AM. |
09-27-2019, 06:10 PM | #14 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
rustoleum has textured paint. really duplicates the bed liner look.
09-27-2019, 07:00 PM | #15 |
Newbie Join Date: Aug 2019 Location: Snohomish County
I used the rattle can bedliner spray I got from O'Reilly's. I think it was the duplicolor. I sprayed it on the outside (obviously) and it worked well. I suggest you run a hobby knife around the edges before you unmask though... |
10-08-2019, 04:47 AM | #16 |
@Jim85IROC - Love the clean look of that Scout in black and white. Textured black roof was the perfect accent. Nice job!
10-10-2019, 11:47 AM | #17 |
RCC Addict Join Date: Jun 2006 Location: Maryland
I used flex seal on the bed of my vs410 pro and love the way it looks. It took a few days to harden up though.
Is there a Paint that mimics bedliner ? - Similar Threads | ||||
truck bedliner | HotRod2507 | Paint and Body | 8 | 11-28-2013 09:51 PM |
Spray on bedliner | josborne024 | Paint and Body | 12 | 03-18-2012 09:59 PM |
My Bedliner.... | BiG_DaWgZ | Paint and Body | 1 | 04-10-2009 09:18 PM |
Hardbody bedliner | BigRocks | Paint and Body | 10 | 05-22-2008 02:01 PM |
Painting with bedliner? | 98TealJ | General Crawlers | 5 | 07-16-2006 10:19 PM |
