11-02-2012, 10:34 AM | #61 |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Re: Szczerba's DRX VE Demon Rally That's what I thought too but, It just works. I started with 5k, 3k, 7k in mine. It worked good. The only thing I didn't like was when she was on black top and the rear would kick way out and I would correct it, she would just spin out. The damn center diff leaks like crazy so I refilled it with 7k. It doesn't spin out as easy now but, I also added the Mamba Monster Max and a huge 3s. I think the weight helped it out.
11-02-2012, 10:37 AM | #62 | |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
I would also love to know more about the diff tuning. To me, the car understeers under throttle, and on tarmac, with high grip tires, the understeer is pronounced. Quote:
11-02-2012, 10:48 AM | #63 | ||||
| Re: Szczerba's DRX VE Demon Rally He does good work, for sure. Thanks. I liked it too. Quote:
I changed to 5k-5k-3k and it handles alot better getting the power to all 4 tires and doesn't push as much. Rootar gave me the advice to keep the front diff and center diff the same weights to start out with and adjust the rear fluild. I am new to the diff tuning game too. I am only running a front sway bar as well. That has helped the rear traction/de-traction department too. Quote:
I do like the 5000mah 3S weight compared to my 3300mah 3S pack. I have only made two diff fluid changes. So my knowlegde is limited. But when I lightened up my fluids all around it seemed to have better power delievery for me. Last edited by Szczerba; 11-02-2012 at 10:52 AM. | ||||
11-02-2012, 10:51 AM | #64 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
I luv to bash these things..had about 5 of them !!! Big props!!!
11-02-2012, 12:54 PM | #65 |
Pebble Pounder Join Date: Jul 2009 Location: Suomi Finland PERKELE !
First, I don't have any experience on DRX's but I've been tearing gravel roads with 4x4 SC trucks and from there I'd say 3-5-1 is good starting point and it keeps the rear under control way batter than 5-7K, 5 in the center is good for loose surface but on tarmac it will eat Your front tires if You over drive the car. If You get decent grip from Your tires You can go higher ( 10-15K works for me ) in center, this brings sharper brakes and acceleration, it will ad undesteer but it shouldn't be a problem when You adapt to it. harder center diff oil will increase motor and esc temps and it will strain batteries more so keep an eye on those.
11-02-2012, 01:30 PM | #66 |
I wanna be Dave Join Date: Nov 2005 Location: Here
I'm going a little thicker. I am trying 10, 10, 30 Obviously it's going to depend on the terrain (of which we don't have a consistent course, yet) and the temps outside. My hope is that they don't unload as easy in the rear to keep forward momentum or kicking the rear out. I may be wrong on it but it is worth a try. I wanted to use 20 but didn't have enough for a diff (you ask why I would save it then, I don't know) |
11-02-2012, 01:44 PM | #67 | |
| Re: Szczerba's DRX VE Demon Rally Quote:
I was also told to go light and work towards heavier fluids if needed. I would think one would want run as light as possible fluids and still have the car drive for them. Ie, not diffing out but still hooking up. Seems like tire wear could be an indicator for fluid changes too. Just my keyboard tuning thoughts. | |
11-02-2012, 02:01 PM | #68 | |
It will be a learning process. The great thing about learning is you are driving.... Reality is that unless you are running the same terrain all the time, the tuning will always be changing. We will see how this goes and I will report back in my thread. | |
11-02-2012, 02:13 PM | #69 |
Rckcrwlr, do You have extra crosspins and gears in the diffs ? if You don't 20 K might work OK but if You do they're as good as spools on power. I'm not saying it's a bad thing You'll just have to drift the corners |
11-02-2012, 02:21 PM | #70 | |
Like I said, we will see how it goes. I ordered some lighter stuff. I believe that no one else is running fluid at our GTG on Sunday so we can see how much it affects the performance...not to mention it will be the first time I am driving it. If it feels like I am fighting with it more than driving it, then I will know that I went to thick. | |
11-02-2012, 11:48 PM | #71 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I don't how you guys are driving it with the thicker oils in the center, that is when mine looped out a lot. Now that I have 3k in the center of mine it is much easier to drive and tracks much better. I was going to even go lower in the center. | |
11-03-2012, 05:19 AM | #72 | |
I haven't run mine yet so we will see. I ordered some lighter fluid just in case. First run is tomorrow. Depending on the terrain, I will adjust accordingly. Just wish these diffs were easier to get to. | |
11-08-2012, 06:07 AM | #73 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
you gonna have that new body by this weekend shane?? looks good.. cant wait to drive it.. |
11-08-2012, 06:08 AM | #74 |
| Re: Szczerba's DRX VE Demon Rally |
11-08-2012, 07:13 AM | #75 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
| Re: Szczerba's DRX VE Demon Rally In my diff's I use Green Grease | The Best Grease Money Can Buy!. ( That's how the link came out. Not endorsing it.) All my rc's get grease. I never use diff fluid. I also only have two gears in the diff. I do have the extra gears if needed. Front shocks are 30wt with medium sway bar. Rear is 27.5wt with hard sway bar. Preload on shocks is 12mm front and rear. Between this setup and the control parameters that the Tekin has over the motor. The car handles very well.
11-08-2012, 07:38 AM | #76 | |||
I liked the stock grease that was in the diffs out of the box but after several battery packs they started spinning too freely and the car would diff out too much. I would probably use just grease if there was a way to "quick fill" the diffs. I put 55wt all around in mine and it's a pretty firm setup. I'll will swap back out to a lighter fluid on the next tear down. I am only running a front sway bar but I only need the two little rod end set screw collars to add the rear. They'll be there today. Not sure when it will get put on though. Last edited by Szczerba; 11-08-2012 at 07:42 AM. | |||
11-08-2012, 07:57 AM | #77 |
Yea, As far as the sway bar goes. Kinda bummed it didn't come with enough hardware to mount both front and rear. I happened to have a traxxas sway bar . Dynamite Slash Front Sway Bar Kit [DYN7909] | RC Cars & Trucks - A Main Hobbies So I used the hardware from that to do the rear.
11-08-2012, 08:05 AM | #78 | |
Hot Bodies Ball Set For Sway Bar 5.8x10mm (4) [HBS66605] | RC Cars & Trucks - A Main Hobbies | |
11-08-2012, 08:15 AM | #79 |
Pics bro.......We need pics of that sexy body on the car. Also durability. Are the aftermarket bodies more durable? Is there less drag with the lower profile body? Do you notice a differance in performance with the Lancer vs C4?
11-08-2012, 08:17 AM | #80 |
| Re: Szczerba's DRX VE Demon Rally Body is still in the hands of the USPS. Probably another couple days before it gets here and I'll have to mount it and finish out the sponsor decals.
Szczerba's DRX VE Demon Rally - Similar Threads | ||||
Team [HOONIGAN]'s DRX(s) | TURTLE | Rally | 314 | 10-30-2021 06:24 PM |
cbp27's DRX Build | cbp27 | Rally | 83 | 08-19-2015 12:23 AM |
kyosho updating the drx | foproy | Rally | 31 | 11-29-2012 09:38 PM |
Micky's DRX VE | mickyteng | Rally | 5 | 11-13-2012 04:11 PM |
drx out of the box | coolair | Rally | 9 | 08-12-2012 12:26 PM |
