11-13-2012, 05:42 PM | #101 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
| Re: Szczerba's DRX VE Demon Rally
The Lancer looks awesome! The pink wheels complete your livery. I used Krylon Fusion on my DRX wheels. I only used some rubbing alcohol to prep them. Some paint rubbed off on the edges of the wheels from curb rash, but if you use black you can use a sharpie to touch them up. Last edited by cbp27; 11-13-2012 at 05:46 PM. |
11-13-2012, 05:44 PM | #102 |
I wanna be Dave Join Date: Nov 2005 Location: Here
| Re: Szczerba's DRX VE Demon Rally |
11-13-2012, 05:49 PM | #103 | |
| Re: Szczerba's DRX VE Demon Rally Quote:
Yep, I don't want to drive this car now! Looks too good. Thanks for the pink color suggestion. Pictures for Page 6 and another shout out to BC Paint's (bcrocks) for painting this up for me. Last edited by Szczerba; 11-13-2012 at 05:57 PM. | |
11-13-2012, 05:52 PM | #104 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
Looks sick! You could also do white front wheel and pink rear.
11-13-2012, 05:55 PM | #105 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
Impressive stuff. A very unique ride!
11-13-2012, 05:56 PM | #106 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
Looks killer Shane, makes me want a drx rally
11-13-2012, 06:03 PM | #107 | |
Thanks. BC Paints did all the hard work on the paint job. You won't be disappointed with the DRX. Like I said before, it's the most fun RTR R/C car I have owned. Handles great, available replacement parts and 4-5 bodies for it. If something were to happen to my garage, it would be the RC I grab first! | |
11-13-2012, 06:30 PM | #108 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
nice! told ya you would like it.. |
11-13-2012, 06:34 PM | #109 |
now your making me wanna get one.. and.. turn my grownovershortcourse track into a rally track.. |
11-14-2012, 05:45 PM | #110 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
| Re: Szczerba's DRX VE Demon Rally Talk about your accessories. Those wheels set your car straight, Man. Damn, That looks good. Are you gonna do lights? |
11-23-2012, 11:08 AM | #111 | ||
| Re: Szczerba's DRX VE Demon Rally Growing on me. Painted some other wheels gray as well. Quote:
Not sure about lights. I am going to make some sort of inner fenders before I run it with this body. Have to stir up something for foams for the new tires too. I should be able to find something in one of my foam bins. | ||
11-23-2012, 12:59 PM | #112 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Szczerba's DRX VE Demon Rally I jammed RC4WD 1.9 foams into mine and they work really well so far. A little bit firmer then the stock foams and don't seem to breaking down as quickly as stock either.
11-23-2012, 01:49 PM | #113 | |
You tried any inner fenders yet? I'll play around with some lexan scraps in a few days. I've found a few ideas from some HPI mini trophy inner fenders guys have done. ,.... Last edited by Szczerba; 11-23-2012 at 02:09 PM. | |
11-28-2012, 08:22 PM | #114 |
Man...that DRX VE sure came a long way totally digging the new paintjob and wheels! I'm seriously considering getting one but I wish it was available in kit form!! But the one thing that keeps bugging me is that Kyosho and Tamiya still use phillips hardware! What's up with that?! I'd even prefer rc4wd's crappy hex screws over damn phillips screws. Grrr...and HPI too why the mix of phillips and hex?! Last edited by alexchen86; 11-28-2012 at 08:24 PM. |
11-29-2012, 05:59 AM | #115 | |
RCC Addict Join Date: Nov 2008 Location: Frederick
12-03-2012, 09:09 PM | #116 |
Thanks guys. I try to convert most to hex hardware when i can. But its still a mix. Been wanting to make some inner fenders to help better protect this body. i remember seeing a HPI Mini Trophy truck having a homemade inner fender. quick search, 0.020" styrene sheet and some sisscors and a rough first front inner fender. if i don run the under body ill have to make another one to go all the way down to the lower chassis. Little notch on fender is to clear the steering linkage on the driver's side. Plan on doing a rear setup soon. Again, just my first try. 0.030 styrene maybe a better thickness. Last edited by Szczerba; 12-03-2012 at 09:11 PM. |
12-03-2012, 09:31 PM | #117 |
Rock Crawler Join Date: Jul 2012 Location: In a van down by the river
What a sweet looking RC! Cheers, Doc (rally envy) |
12-04-2012, 04:29 AM | #118 |
I like the inner fender idea. Thanks for the inspiration.
12-04-2012, 08:33 AM | #119 |
| Re: Szczerba's DRX VE Demon Rally Thanks. 92% credit goes to BC Paints! for spraying the Lancer shell for me. Thanks. It's a little rough for the first prototype but I'll cut another one and get it better. Rear of the fender needs to come down flush with the chassis for more protection if I don't run the underbody. |
12-05-2012, 08:00 PM | #120 |
two pieces of 0.020" of styrene for the rear with two holes drilled. body clips above/below hold it on the posts and double sided tape holds the two pieces together. |
Szczerba's DRX VE Demon Rally - Similar Threads | ||||
Team [HOONIGAN]'s DRX(s) | TURTLE | Rally | 314 | 10-30-2021 06:24 PM |
cbp27's DRX Build | cbp27 | Rally | 83 | 08-19-2015 12:23 AM |
kyosho updating the drx | foproy | Rally | 31 | 11-29-2012 09:38 PM |
Micky's DRX VE | mickyteng | Rally | 5 | 11-13-2012 04:11 PM |
drx out of the box | coolair | Rally | 9 | 08-12-2012 12:26 PM |
