11-06-2012, 03:57 PM | #41 |
I wanna be Dave Join Date: Nov 2005 Location: Here
| Re: Rckcrwlr's Demon Child...Kyosho DRX VE
In haste and knowing how they get tortured on 8th buggies, I ordered a set of Universals for the front. After the fact, I probably should have saved my money and just got some spare dog bones...but they already had shipped. Here they are: We will see how it goes... |
11-06-2012, 05:37 PM | #42 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
Great pictures so far. I really like seeing so many DRX's together. Wish I had someone to run with. Can't wait to see some videos!
11-08-2012, 10:56 AM | #43 |
So I decided for lunch I was going to change my front shafts to the universals. Thinking this would be a quick and easy process was naive of me. I can't get the wheel nuts off. These things are welded on. I tried the tool, then a 10mm rachet...even clamped the tire in place to get a better hand on it... Nothing. I then put the socket on the nut and tapped it thinking that it may loosen...NOPE. May have to put heat on it... |
11-08-2012, 11:02 AM | #44 | |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
| Re: Rckcrwlr's Demon Child...Kyosho DRX VE Quote:
11-08-2012, 11:06 AM | #45 | |
As you figured out, they really put the excessive torque to these wheel nuts from the factory. It was heck getting them off the first time as well. | |
11-08-2012, 11:13 AM | #46 | |
| Re: Rckcrwlr's Demon Child...Kyosho DRX VE I'll use my LRP Soldering Iron at 400 degrees... Quote:
Now you tell me...LOL | |
11-08-2012, 11:21 AM | #47 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
| Re: Rckcrwlr's Demon Child...Kyosho DRX VE Ha, I forgot about that. Yea, Kyosho on tightening those nuts so friggin tight. I thought I was gonna shear the axle.
11-08-2012, 11:31 AM | #48 |
Pebble Pounder Join Date: Nov 2004 Location: Charles Town
Could you try a small impact gun, like a 3/8" drive one? Or hell, hit it with a 1/2" one, it'll either come off or break something |
11-08-2012, 11:59 AM | #49 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
Try throwing it off a cliff. ;) I found the same with mine. Ridiculous.
11-08-2012, 01:44 PM | #50 |
One of the screws in my spur gear was in so tight, I thought they installed it with red loctite.
11-08-2012, 06:46 PM | #51 |
The stock wheel nuts are so tight because they have a serrated face that digs into the wheel. Once you break the initial seal, make sure you really tighten them down again. If they're not super tight they'll spin right off. That's what happened to me so I just replaced them with nylon insert lock nuts from Lowes.
11-08-2012, 07:38 PM | #52 | |
I may need to find another option. I saw yours that you got at Lowes, may be taking a trip there. | |
11-08-2012, 07:52 PM | #53 |
GDB wanted me to post this up... These are pictures of the chassis lid and how well it works... The terrain was pretty muddy... Here is what the Chassis lid looked like... And this shows you how clean it is... Notice that he put some foam in the front and rear to block the openings. Though it shouldn't be an issue now due to the cold weather, the foam may restrict the air and cause high temps in summer heat. |
11-09-2012, 10:03 AM | #54 |
Got my package today with the WRX body and wheels and tires... I have to say that these dirt hawgs (P/L #1071-00) are sick... They are a little wider but I like the tread pattern. Also got some track items... |
11-09-2012, 10:51 AM | #55 |
Can you show the white wheels with the demon body? Did you get the cones local or online? If online, Do you have link? Also, Is there performace differance C4 vs WRX? I know you haven't Driven with the new body yet. Just curious to know if you notice a differance when you do. Last edited by buzzbuzzard; 11-09-2012 at 10:58 AM. |
11-09-2012, 11:03 AM | #56 | |
| Re: Rckcrwlr's Demon Child...Kyosho DRX VE Best I could do being that I still haven't got my Wheel nuts off... Quote:
11-09-2012, 11:45 AM | #57 |
Hmm...... White wheels, white wing and orange demon sticker. Wheels look good. Thanks for the link bro |
11-09-2012, 08:27 PM | #58 |
I got the front tires off...had to use a 24V Impact Gun...Seriously and still tore my hand up. I was able to install the universals...Nice construction, a little more HD than the dog bones but the key is the universal...no popping bones now... Also test fit the Dirt Hawgs. Front has ton of room...looks like rear may rub a little...but I have to try and get those wheel nuts off now. |
11-09-2012, 08:28 PM | #59 |
Also decided to get rid of that battery bar and use velcro.. And as I was doing that I saw this... |
11-09-2012, 09:01 PM | #60 |
I was so confused on the direction of the tread. When I first mounted mine. Here is a picture from proline. |
Rckcrwlr's Demon Child...Kyosho DRX VE - Similar Threads | ||||
Szczerba's DRX VE Demon Rally | Szczerba | Rally | 140 | 09-09-2015 04:09 AM |
Kyosho DRX VE SUBARU IMPREZA WRC | sally1800 | Rally | 59 | 05-24-2013 08:05 PM |
kyosho updating the drx | foproy | Rally | 31 | 11-29-2012 09:38 PM |
Kyosho DRX Ford Fiesta | Stburr91 | Rally | 7 | 10-24-2012 10:11 AM |
kyosho drx ve VS hpi wr8 VS TT01 | phase10 | Chit Chat | 2 | 09-11-2012 12:05 AM |
