11-23-2012, 10:51 AM | #1 |
Pebble Pounder Join Date: Mar 2008 Location: Pittsburgh
| Anyone have bearing/diff issues?
Tore into the diff tonight and found some interesting things. I think what I found may explain a few of things I've noticed over the past couple of weeks. One of the first things I noticed from the start with my car is that when I would come off the throttle suddenly the rear end would want to whip around to the drivers side. I thought maybe it was just a weird torque issue as this is my first high powered brushless setup. The other thing is that I've felt like my car was a battery hog. Today I really noticed it when I had already burned through a 4000 and 2 5000's before most people had finished their second battery. When the rear end let go towards the end of the day I thought maybe I crunched my diff gears. Below is a pictorial of what I found when I tore into it tonight. Sorry if I don't know all the terminology when it comes to the internals. This is what I found when I took the bulkhead off. You can see the outside of the diff case melted and fused to the bearing. Diff casing is gone. Ring gear is shot. Outer diff casing gear is shot too. The good news is the the spider gears inside the diff look perfectly fine and still spin freely. When I looked at the manual it showed two shims between the bearing and the diff case and I could only find one. At this point I think I will need a new rear bulkhead (diff casing), new ring and big diff gear, new bearings and shims, and the diff housing as that frozen bearing tore it all up around the output shaft. I don't know if it just got wet and froze up that first weekend we ran, but like I said I've always noticed the car's tendency to want to spin to the driver's side on decal since I first got it. Maybe it was just a bad bearing from the get go. Any thoughts? Jake Last edited by Patella; 11-23-2012 at 11:01 AM. |
11-23-2012, 10:58 AM | #2 |
| Re: Anyone have bearing/diff issues?
Don't see any pictures. What car you referring to? My Kyosho DRX has smoked rear axle carrier bearings pretty quick. I'll need to fix/upgrade soon. Good thing you found your issue. |
11-23-2012, 11:05 AM | #3 |
Sorry fixed the pics issue. Had tried to import the post over whole from my local forum and pics didn't come over. I"m ordering new bearings for the whole rear end. One of my big wheel bearings lost a shield and was pretty gritty too. Going for rubber sealed. |
11-23-2012, 11:12 AM | #4 |
You don't run any grease on the ring/pinion gears? Also when I tore apart my DRX for the first time. There was only one diff bearing shim on one side as well. |
11-23-2012, 11:16 AM | #5 |
I was just running it stock so whatever was in there.
11-23-2012, 12:57 PM | #6 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Anyone have bearing/diff issues? Yeah you need grease! Really the first thing you need to do when you get this car is open the diffs up, check them, grease them and make sure everything is in place. I have blown two outer bearings on the knuckles in the rear, but that is it. I also rebuilt the entire car and greased EVERYTHING before I ever drove it. Been driving mine now for almost a year with zero diff issues. |
11-23-2012, 02:14 PM | #7 | |
| Re: Anyone have bearing/diff issues? Quote:
11-23-2012, 02:32 PM | #8 | |
11-25-2012, 07:26 PM | #9 |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Re: Anyone have bearing/diff issues? DAMN IT!!! I just repacked all of my diff's with M Grease.
11-25-2012, 08:07 PM | #10 |
| Re: Anyone have bearing/diff issues? Any why it doesn't work is because of how fast the diffs move. I used to run it in my TB-01. I checked them after a couple weeks and the grease had dried out and become a thin layer of tar on my diffs. The heat generated in the diffs drys the grease out pretty quickly. The only luck I have with marine grease is in crawlers and that is because of the slower rate the diffs move and my constant submerging in water. |
11-26-2012, 05:27 AM | #11 | |
11-26-2012, 07:12 AM | #12 | |
Pebble Pounder Join Date: Feb 2012 Location: UK
11-27-2012, 05:22 AM | #13 |
| Re: Anyone have bearing/diff issues? There's one thing I found with mine that's weird. The manual shows two shims on the diff. Both being placed on the ring gear side of the diff. When I put mine back together I put one on each side by accident. Last night I tore them apart and placed both on the same side and, the mesh was way off. It was super tight. Maybe after you rebuild them try and play with the shim placement.
Anyone have bearing/diff issues? - Similar Threads | ||||
Pinion carrier bearing issues | arnesto | RC4WD Trail Finder 2 | 21 | 02-14-2017 08:58 AM |
Summit diff issues? | jaymann | Traxxas Crawlers | 21 | 10-26-2013 11:42 PM |
Diff issues | Toph | Kyosho Crawlers | 16 | 09-05-2009 12:37 PM |
lost bearing seal in the diff......... | bob1961 | General Crawlers | 0 | 06-04-2009 06:14 PM |
wheely king diff bearing | chip cross | General Crawlers | 0 | 02-25-2007 09:41 PM |
