09-09-2015, 12:16 AM | #101 |
RCC Addict Join Date: May 2012 Location: Montreal, Qc
| Re: I like REVOLUTION!!!
Oh yeah and any particular cut pattern on these tires like the Voodoo?
09-10-2015, 03:26 AM | #102 |
So, i cut and installed my CI foam in the bully tires, only thing left is to glue the 5th dimension wheels... Any tips on that??? |
09-10-2015, 08:05 PM | #103 |
Done!!! Foams installed, tires pins cutted, 5th Dimension wheels glued... So ready to compare these to my so-loved Voodoos... will try to ride the same lines at the same spot to be able to see the difference... The Bully tires are narrow but smaller too so yes the cog will be better but the ride height is lower too so what about break over, etc... |
09-10-2015, 09:01 PM | #104 |
Final weight (w/3s 850mah 40c lipo): a hair under 4lbs rtr
09-21-2015, 10:41 PM | #105 |
Love them... compare very much to the voodoo silver... They are really sticky and soft but the sidewall seems a bit thickier so great for side hilling... And they are so narrow, give u an unreal steering without hitting the shocks... The only thing for now is they seems to have a bit less grip on ''direct foward attack'' (foward bite)... Don't know if it because of the smaller pins on these tires...!?! But as i mentionned, i will need a lot more rock time to make myself a full opinion... (break in aren't even complete!) First video on rocks: https://youtu.be/1Gyqoj2KyJ0 Last edited by noname0383; 09-22-2015 at 05:44 PM. |
09-22-2015, 09:19 PM | #106 |
Newbie Join Date: Nov 2011 Location: san diego
nice good to hear i may run these first before i order my voodoos I'm going for a pin ultra narrow in silver what foams are you running in the bullys
09-22-2015, 09:24 PM | #107 |
| Re: I like REVOLUTION!!! 5.5T Double Deuce Narrow Pair (2) front soft outer comp cut and rear medium outer comp cut... And you'll have to narrow the outer same as the stock foams... |
09-26-2015, 04:37 PM | #108 |
Out crawling with new Bully tires on 5th Dimension wheels... |
09-26-2015, 04:39 PM | #109 |
| Re: I like REVOLUTION!!! Last edited by noname0383; 10-02-2015 at 07:54 PM. |
10-04-2015, 02:53 PM | #110 |
Review of the Bully tires by Crawler Innovations... Crawler Innovations Reviews the RC4WD 2.2 Bully Comp Tire |
I like REVOLUTION!!! - Similar Threads | ||||
A revolution in suspensions ? | setecastronomy | Tamiya TLT Crawlers | 24 | 08-18-2009 03:34 AM |
The Revolution | HadakaJime | Chit Chat | 0 | 04-15-2008 07:16 PM |
Be part of the revolution. | Crawl It | Chit Chat | 0 | 12-16-2007 05:53 PM |
Viva la revolution! | slugzracing | Chit Chat | 17 | 10-24-2006 10:44 PM |
2.2 Revolution Article | DirkDigler | Chit Chat | 10 | 05-02-2006 07:45 PM |
