Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Crawlinghulls bullified
Old 05-27-2015, 09:43 AM   #81
Default Re: Crawlinghulls bullified
Nice rig you have. Do you know the hole size of the axle tube need to be to fit the Dlux axle? I figure about 7.5mm, but don't want to do it just yet. Its a no return point, once you drilled it.
Colgout is offline   Reply With Quote
Old 05-27-2015, 02:26 PM   #82
I don't have access to a drill press so I sent them to Erik to be drilled. One side note - depending where the weld is you may need to drill the hole in the case for the axle size increase
crawlinghulls is offline   Reply With Quote
Old 05-28-2015, 05:39 PM   #83
Well did a little testing and tuning and comparing with my wife's rig (xr). what a difference in wheel speed
My Sudu HH 13t 500"crawl"/13t pinion
Hers HH Crawlmaster Pro 13T/14t pinion
Seems like hers is 1/3 faster????
Don't know if going to a 14t pinion is the answer??????
Also - anyone making rear upper link mounts?????
Old 05-31-2015, 05:34 AM   #84
New hubs and some lessons learned, added a small amount of weight. riding at 4lbs 3.1oz
Old 06-01-2015, 05:46 PM   #85
Sorry that it took me so long to see this ..... Should be a little better
Old 06-07-2015, 03:03 PM   #86
Broke the gear pin. So the question is - are the new ones stronger ??? Still managed four progresses on the third course with rear wheel drive only
Old 06-07-2015, 04:04 PM   #87
That didn't take long to Diagnose!
easy fix...
Force5 is offline   Reply With Quote
Old 06-14-2015, 02:15 PM   #88
Hey --- I realize this isn't crawler related but my wife told me to post it up(actually said if I didn't she would). So yesterday at graduation I received this....
Old 06-16-2015, 04:26 AM   #89
Ok so I build up some new tire foam combos - go to mount them up and now they hit the knuckles??????WTF?????
Old 06-16-2015, 06:18 AM   #90
I had the same problem when I first built my rig. You actually have to use the dremel to grind the outside of the screw head so it matches where the carbon fiber is tapered. These knuckles have very little clearance with the wheel hardware.
blandon is offline   Reply With Quote
Old 06-16-2015, 08:11 AM   #91
Custom Carbon Fiber
Robbob's Avatar
Button heads on the inner holes??
stole the picture from a berg thread .......
Robbob is offline   Reply With Quote
Old 06-17-2015, 04:56 PM   #92
They were actually hitting the bottom outer counter sunk screws. I spoke to Erik and he said with certain hub/wheel width it can happen. took a Drexel to the 6-32 screw heads and problem solved.
Also I may have figured out the Bully tire. took a small grinding wheel and a Drexel and sanded the sidewalls of the front tires inside and out, big difference
also experimenting with a different upper link mount - raises upper link mount 1.5mm--- so far so good
Next will be a slightly heavier rear shock oil
Old 06-17-2015, 07:32 PM   #93
I had the same problem after grinding it would tick under load I thought it was a gear but it was the knuckle so I ground some more on the wheel and the screws on the knuckles but I replaced them with titanium so the small head on one side and smaller foot print would and no problems ever over a year
stankulas is offline   Reply With Quote
Old 06-19-2015, 07:40 PM   #94
Got home today to feel the love. Got so excited I forgot to take a pic before tearing into it. So I finally think I got the foams I need. Gotta give props to Crawler Innovations - great product and fantastic customer support
Old 06-23-2015, 08:07 AM   #95
So got her out this past weekend . Switched tires after course one, then the jump through gate 9 and poof. there goes a carbon fiber steering arm
But Purptr8r to the rescue with his cordless dremel
Old 06-23-2015, 09:00 AM   #96
Wanna get? Gotta want.
Erik D_lux's Avatar
Looks like you could just use a straight tie rod?
Once you get that drag link rod end down on the carbon arm instead of spaced up it will relieve a bunch of stress and you should be good to go.
Let me know if you want a new 1/8" ti drag link too. Looks like you could use a bit shorter one.
Erik D_lux is offline   Reply With Quote
Old 06-23-2015, 05:35 PM   #97
So the Bully comp tires have not been cutting the mustard on my 4lb 2oz sudu/bully2. The clubs I compete with run some insane lines and really push the limits. The issue with the bully comp tires seems to be support for the smaller lugs. here's my first attempt at solving the issue
Old 06-29-2015, 05:21 PM   #98
here's a little update - A big thanks to Winnerone23 (advice with electronics), Purptr8r (huge support and advice on the suspension setup) and Erik (Dlux) (dealing with my issues and helping with my steering). Best group of people out there
when you run ofna universal on a bully be sure to drill the inner gear case
Erik updated the design on the axle shaft so you can run stock axle c screws
Shortened and changed angle on the front shocks
Old 07-03-2015, 03:59 AM   #99
Found some 25+year old buggy front wheels - looked like a good match for the Bully Comp tire
Just a heads up - RC4WD has gotten stock levels up and would like to offer a 10% discount on EVERYTHING on the site from July 1 - July 6.
Use promo code: WANTYOUBACK
Old 07-21-2015, 05:23 PM   #100
So home from the NENQ and am pretty pleased with the way the rig is progressing. Picked up a set of Voodovers courtesy of Purpmart (kinda ironic). Snapped the short front axle shaft on course three and had to take a dnf. Finished up in 16th overall
During the day there was a discussion on venting tires vs venting foams. Some claim - why put a hole in a good tire - more chance of tearing. Others say venting the tire is easy and really does not increase the chance of tearing.
Well I have traditionally vented the tire when running the C.I. foam but years ago - before high density foam - back when hpi 1.9 stock wheels were doing work - we vented the wheels. So I found a piece of 3/16 aluminum tubing and just pressed through the foam. Worked like a dream. will be testing soon
Gotta thank Winnerone23 for the idea (tried drilling it but it grabbed the foam so bad it ripped in half)
Crawlinghulls bullified - Similar Threads
Crawlinghulls CCC pitbull crawlinghulls Axial XR10 20 12-08-2014 07:13 PM
