07-22-2015, 10:56 PM | #101 | |
Quarry Creeper Join Date: Jan 2014 Location: Western Wa. Mose Capital of the World
| Re: Crawlinghulls bullified Quote:
MacMasters -Carr sell hardened metric dowel pins Just figure the Dia. and length you need Attachment 322744 Last edited by Tom G; 08-29-2016 at 04:49 PM. | |
08-23-2015, 04:03 PM | #102 | |
Rock Crawler Join Date: May 2007 Location: Norwich
Thanks for the info Quote:
08-23-2015, 04:10 PM | #103 |
Been gone for a bit but I'm back! Turns out the problem was that the magnets in the front motor came away from the can. Sent them out to Holmes and a few days later she's up and running the way she should be. Added some voodoos from Purpmart (awesome tires and great tire setup!) and adding a Creeper Bob Ti rear axle shafts and she's right at 4 pounds First comp back together with the Holmes Hobbies 500's and she took the win. So far I couldn't be happier. |
08-23-2015, 05:28 PM | #104 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
Hay curt there's a mantis for sale on ebay I think you should buy it and run it Way to go there must be sum purple pixey dust on those tires |
08-24-2015, 05:05 PM | #105 | |
RCC Addict Join Date: Jul 2008 Location: San Diego
08-28-2015, 06:00 PM | #106 |
It is going to depend on your setup and driving style (or learning how the tires want to drive). So far my best results have been with a 5.5 soft outer with a tuning ring narrowed, cut and glued (very lightly) to the inside of the tire. Sounds weird but seems to give the lug more support |
03-06-2016, 07:00 PM | #107 |
Well it has once again been some time but the rig has gone through a. Small update - aluminum cross braces on the chassis, aluminum spacers on the shocks, lightweight panels and reworked the wiring - all said she's just under 4 pounds ready to run |
03-06-2016, 07:39 PM | #108 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
Sudu is looking sweet. I like the panels. You may have to get it down a few more grams to be competetive though!! Looking forward to comping with you again.
03-07-2016, 03:07 AM | #109 |
| Re: Crawlinghulls bullified |
05-17-2016, 05:32 PM | #110 |
Pebble Pounder Join Date: Mar 2008 Location: Wallingford, CT.
She dropping more weight now looking good, like those new upper link mounts! |
05-18-2016, 04:05 PM | #111 | |
The new upper link mounts (A huge thanks to ROCKCRUISER) have definitely improved forward bite , some limiting to the front shocks, and a small geometry change in the front - all in all she is more stable Weight is down to 1788 grams rtr | |
05-19-2016, 05:26 PM | #112 |
Realized the suspension was bottoming out due to the chassis and not the shocks so.... larger external limiters and know flex is down but grip is up - been doing this for over 10 years - can't believe I didn't see this earlier.
06-12-2016, 04:00 AM | #113 |
Reworked the battery mount due to the top mount upper link mount- actually might lower the cg a little. Plus, with the lexan bolted to my steering stop the battery strap is "captured". Off to the comp
06-12-2016, 05:17 PM | #114 |
Nice job today and I must say the rig and driver are performing outstanding. I would say anyone running bully and Sudu would be pleased with your setup |
06-15-2016, 08:31 PM | #115 |
thanks for that, I might have a few more tricks up my sleeve, it's a ninja thing. Stan great job driving and dealing with the many hiccups of a new comp location |
06-30-2016, 05:11 PM | #116 |
With everyone making updates and my 3d build moving slowly I figured I better look at my Sudu So here is the update Added offset rod ends to rear upper link and found a few more mm of squat |
06-30-2016, 06:47 PM | #117 |
Looking good! Can't wait to see what's next.
07-08-2016, 07:45 AM | #118 |
Ok - so if offset rod ends are good on one end.... more is better slightly more up travel is found - will be testing this shortly - |
07-08-2016, 08:44 AM | #119 |
No more testing and practice for you!!! Lol... You have that SUDU dialed in nicely and looking good. Look forward to comping and hanging out next week! |
07-08-2016, 08:46 AM | #120 |
Me likey! By the way I'm following you thru each course at Rausch! |
Crawlinghulls bullified - Similar Threads | ||||
Crawlinghulls CCC pitbull | crawlinghulls | Axial XR10 | 20 | 12-08-2014 07:13 PM |
