03-14-2017, 01:30 PM | #61 |
Pebble Pounder Join Date: Jun 2014 Location: North California
| Re: UGLY's Bully 2
Had to drop the 420 shocks and pick up some big bores. TRA2660 2660 Big Bore Long Shocks LOSB1117 Front Shock Springs (3pr) TRA2742X 2742X Rod Ends & Hollow Ball T-Mx DTXBHP310 BHP310 Titanium Button Hex Screw M3x10 Last edited by UGLY; 03-14-2017 at 01:34 PM. |
03-20-2017, 02:35 PM | #62 |
| Re: UGLY's Bully 2 Last edited by UGLY; 03-22-2017 at 01:03 PM. |
03-20-2017, 02:37 PM | #63 |
| Re: UGLY's Bully 2
Used SSD M3 bent links and went with the outside mount. Moved the screw in on my servo horn so it runs parallel. Gives the servo better resolution and holding power. Last edited by UGLY; 03-22-2017 at 01:04 PM. |
03-20-2017, 02:45 PM | #64 |
| Re: UGLY's Bully 2 Last edited by UGLY; 03-22-2017 at 01:07 PM. |
03-20-2017, 02:51 PM | #65 |
| Re: UGLY's Bully 2 Last edited by UGLY; 03-22-2017 at 01:06 PM. |
03-20-2017, 02:56 PM | #66 |
| Re: UGLY's Bully 2
Shortened all the wire to minimal lengths and soldered the esc's power wires together within 1". Also turned all the 14ga wire to 16ga. I saved about 10g by removing excess wire and running 16ga.
03-20-2017, 03:13 PM | #67 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: UGLY's Bully 2
Hey UGLY, why not mount Lipo where your receiver is?
03-20-2017, 03:23 PM | #68 |
| Re: UGLY's Bully 2 The wp1080's are just too bulky for the lipo wires to go anywhere.
03-20-2017, 03:47 PM | #69 | |
Rock Stacker Join Date: Jun 2016 Location: Bulgaria
| Re: UGLY's Bully 2 Quote:
03-20-2017, 05:30 PM | #70 |
| Re: UGLY's Bully 2 I compacted everything
03-21-2017, 02:18 AM | #71 |
| Re: UGLY's Bully 2
You didn't removed the heatsink from the esc? I wonder what will happen if I remove the heatsink ... esc will burn .. or it will work .. |
03-21-2017, 09:48 AM | #72 |
| Re: UGLY's Bully 2 |
03-21-2017, 01:27 PM | #73 |
03-21-2017, 02:31 PM | #74 | |
The resin is the waterproofing poured around the electronics to keep them sealed. I'm guessing it was poured in the casing? | |
03-23-2017, 03:31 AM | #75 |
| Re: UGLY's Bully 2
I'm not sure how much is visible in the pic.... but yeah... resin is covering the electronics and the case... it will be kinda hard to remove Sent from my iPhone using Tapatalk |
03-23-2017, 03:33 AM | #76 |
| Re: UGLY's Bully 2
Maybe some heat may make the resin liquid again... so I can remove the motherboard from the case. The heatsink is is glued too.. :(
03-24-2017, 11:51 AM | #77 |
| Re: UGLY's Bully 2
Ordered some CI foams to pick up today. Is the standard/soft ok? Comp cut are not in stock at all at amain.... return and order comp cut?
03-24-2017, 12:25 PM | #78 |
| Re: UGLY's Bully 2
Pm Eddie at CI Hang up and Drive |
03-24-2017, 07:41 PM | #79 |
| Re: UGLY's Bully 2
Returned and ordered some comp cut foams from ci.com. Also picked up an extra outer to dial in the ruptures. 1 x Double Deuce 5.5” Comp Cut Inner / Soft Outer 1 x Double Deuce 5.5” Comp Cut Inner / Medium Outer 1 x Double Deuce 5.5 / 6.0 Soft Outers w/ Tuning Rings |
03-27-2017, 05:10 PM | #80 |
| Re: UGLY's Bully 2
Big up's to eddie @ CI. Received my foams in literally 1 business day and not only was my order perfect, he included a couple free sets of tuning rings for my ruptures. Top notch customer service and products . Last edited by UGLY; 03-28-2017 at 09:15 PM. |
