Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Is this why my rear axle was slipping?
Old 06-05-2017, 08:45 PM   #1
Default Is this why my rear axle was slipping?
(Bully 2 rear axle)
I noticed two bearings are destroyed here. I don't get how that could happen since it's all held in place in the housing. Anyway if I lock the front axle and just use the rear under any resistance it just slips. The gear mesh all looks fine though. Then I discover busted bearings. Wtf is with this thing? I've only used it in the backyard so far cuz I'm so busy, so not even one outing and it's destroying itself. For over a thousand Canadian dollars. I won't recommend this thing to anyone. Shipping is expensive and takes a long time. God dammit. Out of the 30 day warranty too.
JoelTGM is offline   Reply With Quote
Old 06-05-2017, 08:55 PM   #2
Default Re: Is this why my rear axle was slipping?
Those small bearing are super prone to fail. They actually installed the wrong ones in mine so they failed early too. Looks like yours is extremely gone though. New gears and look into using a bushing there rather than a bearing. Thats how a lot of people fixed that problem. Mine was still under warranty though. If there is anything left of the inner and outer race of the bearing. I would measure it. If it was the wrong size maybe you can talk rc4wd into helping you out. Even though your out of warranty. Worth a try.
Evo93 is offline   Reply With Quote
Old 06-05-2017, 09:06 PM   #3
Okay thanks. I've never used bushings before, do I simply measure the bearing and find a bushing that matches it?
Old 06-05-2017, 09:38 PM   #4
Stock bearings are garbage, upgrade to better bearings.
FYI, that small bearing is 5x9x3. Look for a bushing in that size.
84yoda is offline   Reply With Quote
Old 06-06-2017, 04:32 PM   #5
RC4WD sells a bearing upgrade kit for the Bully II, is it any good? Or would Fast Eddy's be better? I haven't even run mine yet, so I figure if this is going to happen may as well add replace bearings to the 'to do' list.
cloudswimmer is offline   Reply With Quote
Old 06-06-2017, 07:43 PM   #6
Fast eddy for sure.
Old 06-06-2017, 08:15 PM   #7
Fast eddy for sure.
Yeah I have Fast Eddy's in two of my scalers. Its $68.00 to do both B2 axles with Fast Eddy's .. I guess I was cheaping out and hoping RC4WD's $25.00 complete kit would do the job by some miracle lol.
Old 06-06-2017, 09:35 PM   #8
What about these
Look at this on eBay http://www.ebay.com/itm/151902293408
tapped-out is offline   Reply With Quote
Old 06-06-2017, 09:56 PM   #9
Fast eddy needs to be update there site, kinda confusing but you only need one. It does both axles.
Old 06-08-2017, 01:45 PM   #10
Just wanted to update and give credit to rc4wd for shipping me replacement bearings even though I was past the 30 days warranty. I'm gonna look into bushings still but glad they helped me out.
Old 08-30-2018, 05:49 PM   #11
I just ran my Bully 2 for the first time last night and figured it must have a slipper clutch loose or something. Its a bit odd to hear the slipping was caused by the bearings.
This morning I was taking apart the axle to inspect it and replace bearings and I really couldn't see the offending bearings. Before I do the rear I'll try to take a closer look but I'm hoping someone might be able to describe what bearing I'm looking for (out of curiosity) though I will be replacing all of the bearings with a fast eddy kit.
EDIT: I did some more digging and found this post
Evos bully 2 rtr
Originally Posted by Evo93 View Post
So that small bearing went bad fast I guess. Didn't notice it until the gears slipped. Pretty lame. And no one has gears in stock. Looks like I might not make it to my first comp.
Okay that makes sense. It ruined my case too looks like both bearings had actually failed. Look at how egged out the spots they ride in are.. Looks like just a gear and bearings or bushings won't fix it...ugh.
So just for shits n gigs I took the rear apart. And the bearings from the rear fit in those holes way better. They move a little but its probably still drivable. So I'm starting to think they put the wrong bearings in there. They are at least 1mm smaller OD that would explain the premature failure.
Sorry to quote so much but this thread comes up in a search first so I figured it'd help others to compile this here
HumboldtEF is offline   Reply With Quote
Is this why my rear axle was slipping? - Similar Threads
Rear axle keeps slipping out on one side tbh2014 Losi Micro-Rock Crawler 5 08-13-2013 08:43 AM
slipping rear diff Foolsize Redcat Crawlers 19 06-09-2011 03:44 PM
rear axle/driveline is slipping AC-130 Newbie General 4 06-26-2009 01:01 PM
Rear slipping?? jeepmann General Crawlers 3 04-18-2006 10:12 AM
Rear slipping fix icu_runnin General Crawlers 0 12-24-2005 06:56 PM
